Thanks, I recreated the UBAQ myself and it worked…they are using mine now.
Sent: Tuesday, June 09, 2015 4:32 PM
Subject: [Vantage] RE: E9: Updateable Dashboard
Yes you can. There was a bug in earlier 905, but in 702A it works. if you have an issue you can always write a short advanced update to get around it.
Greg
Sent: Tuesday, June 09, 2015 6:15 PM
Subject: [Vantage] E9: Updateable Dashboard
Can you update two tables within one updateable query?
Part and PartPlant?
Miguel A. Santillan
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible
for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately
delete the communication.
"This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported
to foreign persons without prior approval form the U.S. Department of State."
