In Sales Order Automation I am getting a task was cancelled on an 81 line sales order.
I am assuming there is a timeout setting that needs to be adjusted. I have a ticket in with support, but am also asking here in case someone has had the issue before.
Greg
From the event viewer
Astria.Framework.DataContracts.DatalinkBusinessException: A task was canceled. —> System.Threading.Tasks.TaskCanceledException: A task was canceled.
— End of inner exception stack trace —
at Astria.Framework.Datalink.ThirdParty.EpicorERP_SalesOrder.Engine.Query(IDataLinkQuery query)
at Astria.Framework.Business.V2.DataLinkQueryBusiness.ExecQuery(DataLinkQueryPackage dto, IDataLinkQuery dlQuery, Nullable1 documentId, Dictionary2 parameterValues)
at Astria.Framework.Business.V2.DataLinkQueryBusiness.ExecQuery(ExecuteDataLinkPackage package)
at Astria.Service.Company.V2.DataLinkService.ExecuteQuery(ExecuteDataLinkPackage package)
UserID:de29ed46-84b4-4081-9f7d-4971fb3b434f
CompanyID:3414b61d-08bd-4fc9-8364-a4e4972a94c0
InstanceID:3a3639c0-9f08-433c-95e4-e8846e295326
Host:
Source:AAAA0001
Detected Ip:10.10.25.146
@gpayne I’ve not seen that one yet. Looks like maybe a Datalink was taking entirely too long, or was deadlocked/contention with something else in SQL and SQL shut it down?
Do you know which datalink and what the datalink was doing?
It is creating an 81 line sales order. I have another order of the same customer that is 37 lines and worked. I am making a recording but I think it is in pre-check create sales order.
The setting is already in the two config files with a note that it is for SOA and APV2 and each file has a note about the other file… These are the folders and files for increasing the timeout.
Eclipse Client Services folder
Astria.Client.WindowsServices.AutomationService.exe.config
Eclipse Server folder
Web.config
<add key="ErpTimeoutSeconds" value="300" /><!--affects precreate and create in AP2 and SO integrations; default is 180; place this in EclipseServer's web.config for server-based integration-->
