ECOGroup attachments
After opening the attachment window, did you try to do a refresh? The reason I ask is that in 8.03.408 there is a bug on the customer attachments in that they don't show up until you do a refresh. Maybe the same thing is happening here.
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Wednesday, November 9, 2011 6:14 PM
Subject: [Vantage] ECOGroup attachments
Â
We are working thru ECOs in Epicor 905.605 and attaching items to them. Engineering is reporting that the document links disappear when the ECO Group is closed, so we have no record of what the supporting documents are. Is there something wrong with our configuration? I see in Company Configuration there is file System Location and SharePoint Integration. Should we use either or both of those.
Greg Payne
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
Greg Payne
