ECOMtl_UD not show value after Approve/Check In
Hi,
I add a field in ECOMtl_UD called ShortChar01 from UD Column Maintenance. I can see, modifiy and save value this field in Engineering Workbench, when I select Approve / Check In and I reopen the form not appear the saved value for ShortChar01. Any idea how to fix it?
Thank you.
Regards
Hi @mvmoo,
You need to do the appropriate mapping in UD Column Map.
Source: ECOMtl → Target: Erp PartMtl
So u will also need the custom field in PartMtl too.
After you have added the mappings in UD Column Map you may need to do a data model regen to sync the mapping.
Hope this helps.
Hello @ridgea
thank you for your answer, it was useful.
Regards.
