EcoOpr vs partopr
What is the difference between eco tables and non eco tables in reference to a baq?
ECO tables are used in Engineering workbench as temporary and then checked back into Part tables for use in making jobs.
So if I’m understanding correctly you should always use part tables rather than eco tables in baqs, correct?
Yes, unless you are building an ad hoc EWB change log.
I found that thread a little old but I have to ask.
Should the data be still in ECOOpr after Checking the revision in?
I have tested it now and I see that I still have data in that table. I was thinking it will be removed.
Yes, the Eco tables will remain populated even after check in. This creates a rev history within individual revs.
