I am running a BAQ to pull in data for a DMT. Upon inspecting the Operations, I have found that several parts have operation 20 listed twice: Once as ASM, other as CA. When I check in Engineering Workbench, only CA is found. So, why ASM showing up in the table but not in the Engineering Workbench?
What tables are you pulling it from? The ECO tables will keep the data in them after the ECO group is closed/parts are checked back in. You should be pulling the operation information from the PartOpr table.
Did not know that. Thank you!
