EDA - Strange streams Issue
I have a sales database that contains three streams. It has been working great. I wanted to add another stream so I made a clone of the original database so I could test the process without impacting the original. I created the new stream, mapped everything, rebuilt the database and everything is great in this table.
However, there seems to be a problem now with the original database. When I was ready to make the change to the database used in production, I added the new stream exactly as I did in my test and when I rebuilt the table it doesn’t show any data (only zeros) in the new stream. I thought this was a problem with the new stream but when I look at the other steams that used to show data, all but the primary stream show zeros. I removed the new stream, rebuilt the table and the primary stream shows data but none of the other streams show data. It’s almost like an internal link is broken somewhere. I could potentially rename the “test” database I had created but the original database is used in several dashboards and I don’t want to have to rebuild them.
Am I missing something related to streams? Any advice on how to correct?
Note that the new and existing streams are mapped exactly like they are in the cloned db which works. Just for some reason the original db is now broken.
EDA as in “Event-driven architecture”?
Sorry I don’t know what you could be working on but…
I would be interested in any context, if you can explain how it’s related to Epicor?
Epicor Data Analytics – their cloud based data analytics tool they resell from Phocas Software.
Thanks…
Yet another topic I know nothing about.
(A category which is grows epxonentially with each passing year).
