Hi, I want to try both EDD and EDA but I can’t find any technical PDF Documentation for both of them. It will be very helpful if there is PDF Documentation. Can anyone give me links for both PDF? I’ve been searching it up on google and Epicor portal but still no luck
There is no real documentation on EDA other than the online help found by using the links inside the UI. Make sure you get into the Phocas Users Group (PUG) as well.
@MikeGross thanks for your answer, how about Installing Epicor. do you have any documentation recommendations for that? When I tried Epicor for the first time I already have preinstalled Epicor using Hyper-V Image.
There is plenty of ERP documentation out there on EpicWeb - form technical guides to installation guides. Lots to Read!
