Editing .DBF file (for Crystal)
The most effective tool is VFP but is a bit expensive for casual table
manipulation. For a simple alternative there is always something like
dbfviewer:
http://www.webattack.com/get/dbfviewer.html
Good luck,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
Sent: Tuesday, May 04, 2004 9:38 AM
Subject: RE: [Vantage] Editing .DBF file (for Crystal)
That makes sense too because when I notepad edit then CR complains about
indexes not found. When I open in autovue there are some non-character
(binary) items at the start of the file, likely those indexes. Excel seems
to scramble them pretty bad because using an edited DBF that way crashes CR
altogether.
I ended up printing the wrong WC code to trigger the extra stuff and using a
black sharpies pen to write over it with the new code. All they wanted was
a sample for the a process instructions meeting for the new code's
procedures.
-Todd C.
Sent: Tuesday, May 04, 2004 11:26 AM
Ok, I will retract the bit about excel, but trying in access seems to point
to the reason. Something about an index file that is expected.
Sorry, I can't be of more help on this.
Aaron
Sent: Tuesday, May 04, 2004 11:20 AM
Subject: [Vantage] Editing .DBF file (for Crystal)
Might be either really easy or impossible but.... what would I use to
edit the .dbf file being used by Crystal Job Traveler? I am testing
some new features added that are triggered by Work Center code and we
have no jobs entered with the new WC code (and no test DB at the moment
to play with). I wanted to edit the .dbf file with notepad but this
apparently corrupts it some how. Excel also affects it so Crystal won't
read it.
Any suggestions for manually altering the .dbf files?
Todd Caughey
Harvey Vogel Mfg. Co.
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service < http://docs.yahoo.com/info/terms/> .
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=129fld3tg/M=295196.4901138.6052515.3001176/D=groups
/S=1705007183:HM/EXP=1083774498/A=2128215/R=0/SIG=10se96mf6/*http://companio
n.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6052515.3001176/D=groups/S=
:HM/A=2128215/rand=124861623>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
Yahoo! Groups Links
Might be either really easy or impossible but.... what would I use to edit the .dbf file being used by Crystal Job Traveler? I am testing some new features added that are triggered by Work Center code and we have no jobs entered with the new WC code (and no test DB at the moment to play with). I wanted to edit the .dbf file with notepad but this apparently corrupts it some how. Excel also affects it so Crystal won't read it.
Todd Caughey
Excel seem to work.
HTH
Aaron Hoyt
Hittite Microwave
read it.
Todd Caughey
_____
Yahoo! Groups Links
Service <http://docs.yahoo.com/info/terms/> .
point to the reason. Something about an index file that is expected.
Aaron
read it.
Todd Caughey
_____
Yahoo! Groups Links
Excel will open them, but I think it hoses up the indexes. Access will
work, and should keep the indexes working. Make sure you have all the
files, not just the .DBF -- there are others, CDX & FPT that are needed too.
-Wayne Cox
Twenty Three -- Information Technology Consulting
828-685-2338
That makes sense too because when I notepad edit then CR complains about indexes not found. When I open in autovue there are some non-character (binary) items at the start of the file, likely those indexes. Excel seems to scramble them pretty bad because using an edited DBF that way crashes CR altogether.
I ended up printing the wrong WC code to trigger the extra stuff and using a black sharpies pen to write over it with the new code. All they wanted was a sample for the a process instructions meeting for the new code's procedures.
-Todd C.
Aaron
read it.
Todd Caughey
_____
Yahoo! Groups Links
ADVERTISEMENT
<http://rd.yahoo.com/SIG=129fld3tg/M=295196.4901138.6052515.3001176/D=groups/S=1705007183:HM/EXP=1083774498/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6052515.3001176/D=groups/S=:HM/A=2128215/rand=124861623>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
