GetCustomer was the best option, it returns all fields from just the
customers table. GetRows and GetByCustID returned the full dataset,
including all ship tos. The response data went from over 6 megs down to
just 42K by using GetCustomer. Thanks for the help!
Of Matt Caldwell
Sent: Tuesday, September 02, 2008 9:06 AM
Subject: RE: [Vantage] Re: Editing Web Services
GetRows causes service connect to time out. I am looking into the other
methods right now. Might use GetCustomer. I will look into GetByID
and GetByCustID as well. Thanks!
Behalf
Of bw2868bond
Sent: Tuesday, September 02, 2008 9:03 AM
Subject: [Vantage] Re: Editing Web Services
Oops - too fast on the click finger...
Depending on the data you have available to look up the customer...
GetByID or GetByCustID will get you full Dataset
GetRows will also return full dataset based upon a query
bw
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> ,
Behalf
Of Matt Caldwell
Behalf
Of bw2868bond
bw
>database. I
> I would like the web service to pull extra data from the
> would like it to pull the customers email address in addition towhat
> GetList normally pulls .<mailto:vantage%40yahoogroups.com>
Behalf
> Of nmtaylor1969<mailto:vantage%40yahoogroups.com>
> Sent: Tuesday, September 02, 2008 8:41 AM
> Subject: [Vantage] Re: Editing Web Servicesyour
> Matt,
> Are you suggesting that you want to pull a few more fields from
> input data and have the web service store this information in the<mailto:vantage%40yahoogroups.com>
> database...?
> Thanks,
> Nick
> "Matt Caldwell" <matt@> wrote:have
> > Can you edit web services that service connect uses? I am using a
> > CustomerService.GetList web service, but I need to add a couple of
> > fields to it.. Is that possible? If it is, how much of a chore is
> > that?
> > Matt Caldwell
> > Technical Support Analyst
> > KERUSSO
> > P.O. Box 32
> > Berryville, AR 72616
> > Phone: 800-424-0943 Ext. 231 or 870-480-4530
> > Fax: 870-423-3568
> > Web Site: http://www.kerusso.com
> > CONFIDENTIALITY STATEMENT:
> > This message, from Kerusso Inc., contains information
> > which is privileged and confidential and is solely for the use of
> > the intended recipient. If you are not the intended recipient, be
> > aware that any review, disclosure, copying, distribution, or use
> > of the contents of this message is strictly prohibited. If you
> > received this in error, please destroy it and notify usimmediately
> > at: 800-424-0943[Non-text portions of this message have been removed]
