Education Blank Title 110465
Epicor does a bunch of behind the scenes stuff with report data
definitions and temporary XML files, which Crystal then uses - that's
causing your blank report. You need to update the data source in
Crystal to the new XML file. The ICE Tools book (downloadable from
EpicWeb) has a chapter or two on modifying reports, including that step.
Brian.
Of jan.sweigart
Sent: Tuesday, May 22, 2012 10:35 AM
Subject: [Vantage] education
Am new to crystal for Epicor - what is the best way to learn about the
links? When I try to add a new link to any report/form, I am getting a
blank report. thanks
Am new to crystal for Epicor - what is the best way to learn about the links? When I try to add a new link to any report/form, I am getting a blank report. thanks
Epicweb is a a good resource.
There you can find knowledgebase documents and user manuals that will cover the report basics.
https://epicweb.epicor.com/Pages/default.aspx
You'll need to set up your account if you haven't already.
