Its awful and hacky but you could write to a file on the server... since you
are only using it for a second while you verify it should work ok. Just make
sure you have a Unique ID in case more than 1 authorization needs to happen
at a time. Or you can be "real creative" and create a new file per
authorization since you are deleting them when u are done anyways.
*Jose C Gomez*
*Software Engineer*
*NEED HELP WITH AN EPICOR ISSUE THAT CAN NOT BE SOLVED ON THE LIST?
CHECK OUT MY NEW BLOG <http://www.usdoingstuff.com> OR CONTACT ME DIRECTLY*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Sun, Jun 5, 2011 at 9:48 AM, CarlH <carl.heeder@...> wrote:
> We're being asked to include electronic signature process in several areas
> of Vantage 8.03
> So far, I've been able to store an "authorization" code in each user's
> account and, when needed, asked the user to enter that number in a darkened
> field on a data input form that is linked to a UD field in one of the
> related tt tables, then with a pre-BPM, verify that the input value matches
> the user's "authorization" code and delete the value from the UD field.
> This works great and is acceptable to our quality people.
> But with PO authorizations, there are no UD fields available nor are there
> any unused data fields that I could borrow.
> Does anyone have any ideas other than going to E9?
