If I had a dime for every time I've heard "I've been told........."
I'd have enough money to waste circling the earth in a coffin like that
Cirque du Soleil guy recently!
Of Rob Bucek
Sent: Tuesday, October 13, 2009 5:35 PM
Subject: RE: [Vantage] Re: Electronic Travelers in Vantage
I've been told that out of the box you can launch UD forms from
MES....of course..I've been 'told' things before LOL!
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Brian W. Spolarich
Sent: Tuesday, October 13, 2009 4:20 PM
I suspect this is more of a 'policy limitation' than a technical one. I
would be worried that this might get broken in an upgrade at some point.
Does this work in E9?
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@...
<mailto:bspolarich%40advancedphotonix.com> ~ 734-864-5618 ~
www.advancedphotonix.com
Behalf Of Rob Bucek
Sent: Tuesday, October 13, 2009 5:01 PM
Are you kidding me??!! Is it that retardedly simple? Im not a
programmer by any means..I even offered to pay the programming group at
Epicor to let me launch a UD table from MES and they said it was
impossible...my opinion of them has sunk to an even lower level than
before...if it were imaginatively possible at that..
Rob Bucek
FAX: (715)284-4084
Behalf
Of mmcwilliams22
Sent: Tuesday, October 13, 2009 3:50 PM
Subject: [Vantage] Re: Electronic Travelers in Vantage
Make a copy of the DLL on the client & server & rename it like so:
Epicor.Mfg.UI.HHUD01Entry.dll
instead of Epicor.Mfg.UI.UD01Entry.dll
Create your subprocess as a non Menu Item & for the program put in.
Then create a Process Calling
Called Process Reference: Epicor.Mfg UI.HHUD01Entry
Called From: Epicor.Mfg.Menu.Mes
select the Menu ID created in subprocess.
Create you button & then on the click event
ProcessCaller.LaunchForm(oTrans,"Epicor.Mfg.UI.HHUD01Entry")
They don't even have to put an employee ID in after putting in Vantage
credentials. Unless of course you want to launch it from another form
like ReportQuantity.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> ,
Behalf Of mmcwilliams22
Of Rob Bucek
Rob Bucek
FAX: (715)284-4084
Picometrix
bspolarich@...
Behalf Of Rob Bucek
Rob Bucek
FAX: (715)284-4084
Behalf
Of mmcwilliams22
>/ Picometrix
> Care to elaborate? ;-)
> bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com<mailto:vantage%40yahoogroups.com>
> Sent: Tuesday, October 13, 2009 4:30 PM<mailto:vantage%40yahoogroups.com>
> Subject: [Vantage] Re: Electronic Travelers in Vantage[Non-text portions of this message have been removed]
> FYI- Accessing the UD Tables from MES can be done.
