# Email address formats in SSRS Email/Fax setup **Category:** [Epicor ERP 10](https://www.epiusers.help/c/e10/5) **Created:** 2016-12-06 13:51 UTC **Views:** 1233 **Replies:** 2 **URL:** https://www.epiusers.help/t/email-address-formats-in-ssrs-email-fax-setup/36514 --- ## Post #1 by @ckrusen What's the truth about about email address formats used in the SSRS Email/Fax setup dialog within the Auto Print action of a Data Directive? Do I need to enclose the addresses within "<" and ">" ? Do I use a comma or semi-colon as the separator ? Is there a difference between whether the address is internal or external? I seem to recall this was an issue in V8. --- ## Post #2 by @Gotschall We are on V8 and there is an issue between Vantage and Exchange. The only way I was able to resolve it is to use Windows as a SMTP server and relay email from Vantage through Windows SMTP to Exchange. Steven G. --- ## Post #3 by @jkane If you are only entering 1 email address, all you have to do is type it in. If you are entering more than 1, you need to put each email address in <> and a comma between each address. Like this: `,` This is the only way multiple addresses will work in that specific dialog box. It took me a while to figure it out. --- **Canonical:** https://www.epiusers.help/t/email-address-formats-in-ssrs-email-fax-setup/36514 **Original content:** https://www.epiusers.help/t/email-address-formats-in-ssrs-email-fax-setup/36514
