Email field length
Hi Michelle,
> It is the latter. What do you mean by distribution lists? Is that in
> customization?
No, it's in your email server. Most email servers allow you to create
distribution lists like sales@... or helpdesk@.... The email
server looks up the address and sees that it's a distribution list and sends
an email to each person on the list. In a different system, we used to email
reports as PDF files. We created a list for each person who received the
report and put their names in that list. If someone moved to another
department or if a new employee started, we just added or removed users
without changing any embedded code.
Mark W.
Is there an easy way to change the field length of a field in Vantage? I want to change the length of the email field in the account.
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
513-716-6400 (direct)
513-382-3281 (cell)
513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@...3A90]
Uh no...that requires programming from Epicor and then major schema
changes.....It's why it is a pain to upgrade from 6.1 to 8.0 and
8.03....they changed the length of several key fields, and then some!
That is if you are talking about the number of characters allowed.
If you are talking about just making the length of the box longer to see
everything in the field, then that is a customization.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Michelle de la Vega
Sent: Wednesday, August 13, 2008 3:51 PM
Subject: [Vantage] email field length
Michelle de la Vega
Cold Jet, LLC
513-382-3281 (cell)
513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com <http://www.coldjet.com> >
<mailto:image001.jpg%4001C8FD64.CFBB3A90> ]
Hi Michelle,
Do you really have that long of an email or is it multiple emails? If the
latter, consider using a distribution list. I like distribution lists even
if they hold one address because it's easier to change those than it is to
find and replace addresses in BPMs, BAMs, VB customizations, etc.
Mark W.
Mark,
It is the later. What do you mean by distribution lists? Is that in customization?
Thanks for your help.
Michelle de la Vega
Cold Jet, LLC
513-382-3281 (cell)
513-831-1209 (fax)
[cid:image001.jpg@...526390]
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark Wonsil
Sent: Wednesday, August 13, 2008 5:02 PM
Subject: RE: [Vantage] email field length
Hi Michelle,
Mark W.
