Email Notification BPM error
Hello guys i am working in a BPM that send an email notification to a person that place a maintenance request when the maintenance job get close.
this is my code
foreach(var job in (from ordrow in ttJobHead
where (string.Equals(ordrow.RowMod, IceRow.ROWSTATE_UPDATED, StringComparison.OrdinalIgnoreCase))
select ordrow ))
foreach(var mr in ( from mrrow in Db.MaintReq
where (mrrow.Company == job.Company)&& (mrrow.JobNum == job.JobNum)
select mrrow ))
foreach(var uf in ( from ufrow in ttUserFile
where ufrow.DcdUserID == mr.Requestor
select ufrow ))
if(job.JobClosed == true)
var mailer = this.GetMailer(async: true);
var message = new Ice.Mail.SmtpMail();
message.SetFrom(“EpicorTest10@ecoreintl.com”);
message.SetTo(uf.EMailAddress.ToString());
//message.SetCC()
//message.SetBcc()
message.SetBody(“
test message
//Dictionary<string, string> attachments = new Dictionary<string, string>();
//attachments.Add(“MyFirstAttachment”, @“\MyServer\myFolder\MyFile.pdf”);
mailer.Send(message);
this is the error i get when i test it
Error Detail
Description: BPM runtime caught an unexpected exception of ‘EntityException’ type.
See more info in the Inner Exception section of Exception Details.
Inner Exception: New transaction is not allowed because there are other threads running in the session.
Program: System.Data.Entity.dll
Method: BeginDbTransaction
Original Exception Type: EntityException
Framework Method: SaveChanges
Framework Line Number: 328
Framework Column Number: 17
Framework Source: SaveChanges at offset 391 in file:line:column c:_Releases\ICE\3.1.400.20\source\Framework\Epicor.System\Data\IceDataContext.cs:328:17
Just guessing but you have three foreach loops running and inside the last one you are creating a mailer. It might not be able to do this. I wonder if you add your user mail to info into a list outside of your loops and then iterate through the list to mail, rather than trying to do it while you are iterating through all of the other stuff.
I think Aaron nailed it
Aaro, do you mean create the email outside the loop and put inside the loop the line that send the email?
thanks for your help
Aaron what i did was declare the mailer and the message variable outside of the loops and that fixed it
Glad to hear!
thanks for your help guys
