Email Reports to Users in Epicor
Anitha,
If the report is a pure ODBC report, we use a tool called "Crystal Delivery" (Groff Automation). This allows us to run the report in a batch mode, allows us to specify parameters to pass to the program, defines the output (pdf, html, printer, etc.), and then we email the report.
We have a number of "scheduled" reports that go out via the windows scheduler, as well as "ad hoc" reports which get kicked off by a user (they check a box, we have a BAM on the box that writes a file, then we pick up that file and run the report).
The downsides to this method are that they need to be ODBC only reports, haven't figured out how to pick up a BAQ/XML report. We're finding that lots of ODBC connections are causing problems, so we'd really like to figure out how to pick up a BAQ report.
Kevin
--- In vantage@yahoogroups.com, "anithayedavalli" <anithayedavalli@...> wrote:
> Hi,
> The report has to be self served.
> Regards,
> Anitha
> --- In vantage@yahoogroups.com, "Gerry Loranger" <gloranger@> wrote:
> > You run the report, save it as a PDF and email it to the sales people. Would
> > that work for now or does it need to be self-serve?
> > Gerry
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> > anithayedavalli
> > Sent: Friday, October 09, 2009 10:30 AM
> > Subject: [Vantage] Email Reports to Users in Epicor
> > Hi Everybody,
> > I have a report "monthly sales report by salesrep".Each salesrep takes care
> > of a region.The sales rep do not have access to epicor.I need to figure out
> > a way to email the monthly sales report to sales rep(according to their
> > regions).How do I go about doing this in epicor.We do not have a crystal
> > distributor to do this.Please reply back urgently as I already have a
> > deadline at my work place.
> > Thank You,
> > Regards,
> > Anitha.
Hi Everybody,
I have a report "monthly sales report by salesrep".Each salesrep takes care of a region.The sales rep do not have access to epicor.I need to figure out a way to email the monthly sales report to sales rep(according to their regions).How do I go about doing this in epicor.We do not have a crystal distributor to do this.Please reply back urgently as I already have a deadline at my work place.
Thank You,
Regards,
Anitha.
Gerry
anithayedavalli
Hi Everybody,
Thank You,
Regards,
Anitha.
Hi,
Regards,
Anitha
> Gerry
> anithayedavalli
> Hi Everybody,
> Thank You,
> Regards,
> Anitha.
We use cViewManager for these types of reports. I know you can use
Vantage for scheduling report to be emailed as well.
Travis
Of anithayedavalli
Sent: Friday, October 09, 2009 9:54 AM
Subject: [Vantage] Re: Email Reports to Users in Epicor
Hi,
Regards,
Anitha
Would
> Gerry
Behalf Of
> anithayedavalli
> Hi Everybody,
care
figure out
their
crystal
> Thank You,
> Regards,
> Anitha.
M-B Companies Confidentiality Notice:
This message is being sent by M-B Companies. It is intended exclusively for
the individuals and entities to which it is addressed. This communication,
including any attachments, may contain information that is proprietary,
privileged and confidential if you are not the named addressee; you are not
authorized to read,print,retain copy or disseminate this message or any part
of it.If you have received this message in error, please notify the sender
immediately by email.
But how do you do with a Vantage report (system or BAQ)? You need to schedule the report to generate its XML, and then you have to run the RPT and XML file in the crystal runtime, and then send e-mail.
I've never been clear on this and would love to see some specifics.
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Late, Travis
Sent: Friday, October 09, 2009 11:14 AM
Subject: RE: [Vantage] Re: Email Reports to Users in Epicor
Travis
Of anithayedavalli
Hi,
Regards,
Anitha
Would
> Gerry
Behalf Of
> anithayedavalli
> Hi Everybody,
care
figure out
their
crystal
> Thank You,
> Regards,
> Anitha.
Hi,
I have been trying to work this out but this is how far I have got. Sorry the details aren't here , its time to go home but gives you an idea...
It assumes a schedule email / report also assumes a third party tool but a bit code can be easily written
1) Create a New Vantage USer > E.g. VantageReport. This is so that the schedule report dumps the xml into a specified folder.
2) Create a schedule weekly etc or whatever
3) Add a report to the above schedule
4) Copy the crystal report and rename
5) On the windows create a batch file
CHECKS
IF EXIST "D:\epicor\mfgsysdata\Reports\VantageReport\BAQ Report -VTProjectNA-*.xml" GOTO TRIGGER_1
GOTO FINISH
:TRIGGER_1
Copy "D:\epicor\mfgsysdata\Reports\VantageReport\BAQ Report -VTProjectNA-*.xml" "D:\epicor\mfgsysdata\Reports\Reportsbin\BAQReport-VTProjectNA-.xml"
DELÂ "D:\epicor\mfgsysdata\Reports\VantageReport\BAQ Report -VTProjectNA-*.xml"
:FINISH
You will need to change the relevant info. This checks for a file in the vantagereport file copies it create a static xml and deletes the original . schedule it so it has time for the xml file to be completed. e.g. 30mins later.
6) create a folder for the new xml. Reportsbin as above
7) Run the process manually to generate the xml
8) Taking the copy of the crystal point to the new xml file.
9) Using Groff automation, or another tool, create the scheule to generate the pdf and email. Or a bit vb code etc...
Its tricky at first but the trick is to get a static filename for the xml.....
Â
Sent: Friday, 9 October, 2009 16:16:20
Â
    bspolarich@advanced photonix. com ~ 734-864-5618 ~ www.advancedphotoni x.com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Late, Travis
To: vantage@yahoogroups .com
Travis
Of anithayedavalli
Hi,
Regards,
Anitha
--- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ,
Would
> Gerry
> From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf Of
> anithayedavalli
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> Hi Everybody,
care
figure out
their
crystal
> Thank You,
> Regards,
> Anitha.
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups. yahoo.com/ group/vantage/ files/.
(2) To search through old msg's goto: http://groups. yahoo.com/ group/vantage/ messages
(3) To view links to Vendors that provide Vantage services goto: http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
Send instant messages to your online friends http://uk.messenger.yahoo.com
