Emailing Invoice Sometimes Adds More Than One Invoice PDF Attachment to an Email
Hello,
Hello,
I am looking for some help with a customization (ARInvoiceForm) that has to be created for in regards to email invoice customers.
We have a customer that will accept one pdf per email sent. Now our customization seems to add multiple PDF invoices to the email and then it’s being sent to this customer.
Is it possible to get this code to email one attachment at a time? If so, how do I tell the code to do this?
// ** Wizard Insert Location - Do not delete ‘Begin/End Wizard Added Variable Initialization’ lines **
	edvInvoiceGrp = ((EpiDataView)(oTrans.EpiDataViews["InvcGrp"]));
	edvHeadList = ((EpiDataView)(oTrans.EpiDataViews["InvcHeadList"]));
	this.btnPrintAutoEmailInvoice.Click += new System.EventHandler(this.btnPrintAutoEmailInvoice_Click);
	epiSession = (Epicor.Mfg.Core.Session)ARInvoiceForm.Session;
	this.btnPostInvGrp.Click += new System.EventHandler(this.btnPostInvGrp_Click);
	DynamicQuery _dq = new DynamicQuery(((Session)oTrans.Session).ConnectionPool);
	DataSet ds = _dq.ExecuteByID("MSIUK-baq-btnAutoEmailFinance");
	bool found =false;
	foreach(DataRow dr in ds.Tables[0].Rows)
		if(dr["UserFile.DcdUserID"].ToString().ToUpper().Equals(((Session)oTrans.Session).UserID.ToUpper()))
				found = true;
	btnPrintAutoEmailInvoice.Enabled = found;
	btnPostInvGrp.Enabled = found;
	this.btnPrintAutoEmailInvoice.Click -= new System.EventHandler(this.btnPrintAutoEmailInvoice_Click);
	edvInvoiceGrp.Dispose();
	edvHeadList.Dispose();
	edvInvoiceGrp=null;
	edvHeadList = null;
	this.btnPostInvGrp.Click -= new System.EventHandler(this.btnPostInvGrp_Click);
	// Begin Custom Code Disposal
	// End Custom Code Disposal
private void btnPrintAutoEmailInvoice_Click(object sender, System.EventArgs args)
	if(txtCustID.Text.Length>0)
	string LockStatus = edvInvoiceGrp.dataView[edvInvoiceGrp.Row]["LockStatus"].ToString(); // only invoice group with lock status having "Not Posted can be processesd.
	       																				// other status such as "Reviewing" cannot processed.
		if(LockStatus == "Not Posted")
		 try
				 Cursor.Current = Cursors.WaitCursor;
				btnPrintAutoEmailInvoice.Text = "Processing..";
				btnPrintAutoEmailInvoice.Enabled=false;
				subLoopAllInvoiceAndEmail();
				Cursor.Current = Cursors.Default;
          catch(System.Exception ex)
				ExceptionBox.Show(ex,"btnPrintAutoEmailInvoice");
		else
		MessageBox.Show(String.Format("Cannot Process! Invoice Group Status = {0}",LockStatus),"Invoice Group Posting Exception");
	else
	 MessageBox.Show("Cannot Process! Invoice Group Null!","Invoice Group Posting Exception");
private void subLoopAllInvoiceAndEmail()
	try
	// EpiDataView edvInvoiceGrp = ((EpiDataView)(oTrans.EpiDataViews["InvcGrp"])); // invoice grp detail
		string custID;
		string InvoiceNum;
		string CustInvoiceEmailId;
		if(edvHeadList.dataView.Count>0) // check any invoice avilable in the invoice group
			for(int RowCount = 0; RowCount < edvHeadList.dataView.Count;RowCount++) // loop through each invoice
				// custID = edvHeadList.dataView[RowCount]["CustomerCustID"].ToString(); //get customer ID of each invoice
				//CallCustomerAdapterGetDataMethod(custID); //validate email id for customer  // <---- VALIDATION DONE IN REPORT. DOING VALIDATION CLIENT SIDE, SLOW THE SYSTEM
				InvoiceNum = edvHeadList.dataView[RowCount]["InvoiceNum"].ToString(); //get invoice number of each invoice
				subEmailInvoice(Convert.ToInt32(InvoiceNum)); //send Invoice Email
		    	PauseForMilliSeconds(3000);
			btnPrintAutoEmailInvoice.Text = "EMail";
			btnPrintAutoEmailInvoice.Enabled=true;
			EpiMessageBox.Show("Invoice E-Mail, sent to all Customers" + "\n" + "Please your check your Outlook OutBox/Sent Items!","AutoEmail");
		else
		MessageBox.Show("No Invoices in the Invoice Group","Invoice Group Posting Exception");
		btnPrintAutoEmailInvoice.Text = "Print";
	catch (System.Exception ex)
		ExceptionBox.Show(ex);
private void CallCustomerAdapterGetDataMethod(string id) // check invoice email id avilable for the customer. if not set angie email id.
	try
		// Declare and Initialize EpiDataView Variables
		// Declare and create an instance of the Adapter.
		CustomerAdapter adapterCustomer = new CustomerAdapter(this.oTrans);
		adapterCustomer.BOConnect();
		adapterCustomer.clearData();
		// Declare and Initialize Variables
		// Call Adapter method
		System.Data.DataSet dsCustomer = adapterCustomer.GetData(id);
	    EpiDataView edvCust = new EpiDataView();
        edvCust.dataView = new DataView(adapterCustomer.CustomerData.Customer);
		string Email = edvCust.dataView[edvCust.Row]["ShortChar02"].ToString(); // customer invoiceEmail Id (i.e. Customer.Shortchar02)
	       if (Email.Length <= 0)
            edvCust.dataView[edvCust.Row].BeginEdit() ;
            edvCust.dataView[edvCust.Row]["ShortChar02"] = "Angie.Dean@msi-forks.com";
            edvCust.dataView[edvCust.Row].EndEdit();
			adapterCustomer.Update();
			else
				//MessageBox.Show( edvCust.dataView[edvCust.Row]["ShortChar02"].ToString());
		// Cleanup Adapter Reference
		dsCustomer.Dispose();
		dsCustomer = null;
		edvCust.Dispose();
		edvCust=null;
		adapterCustomer.Dispose();
		ExceptionBox.Show(ex, "Customer Get Data ");
public void subEmailInvoice(int invoiceNum) // get invoice number and send email using edocprinter
Epicor.Mfg.Rpt.ARInvForm ARInv = new Epicor.Mfg.Rpt.ARInvForm(epiSession.ConnectionPool);
Epicor.Mfg.Rpt.ARInvFormDataSet ARInvDs = ARInv.GetNewParameters();
     try
            if (invoiceNum > 0)
               ARInvDs.Tables["ARInvFormParam"].Rows[0]["InvoiceNum"] = invoiceNum;
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["Vouchering"] ="False";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["PrintNPost"] = "False";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["AssignLegalNumber"] = "False";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["DocTypeOption"] = "All";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["EnableAssignLegalNumber"] = "False";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["PrintStatusOption"] = "All";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["TransOptions"] = "ARC";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["TH-IsService"] ="False";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["AutoAction"] = "Print"; //use "Preview" to preview the report
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["PrinterName"] = "eDocPrinter PDF Pro";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["AgentSchedNum"] = 0;
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["AgentID"] = "SystemTaskAgent";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["AgentTaskNum"] = 0;
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["RecurringTask"] = "False";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["RptPageSettings"] = "Color=True,Landscape=False,Margins=[Left=100 Right=100 Top=100 Bottom=100],PaperSize=[Kind=\"A4\" Height=1169 Width=827],PaperSource=[SourceName=\"Auto\" Kind=\"AutomaticFeed\"],PrinterResolution=[X=600 Y=600]";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["RptPrinterSettings"] = "PrinterName=\"eDocPrinter PDF Pro\",Copies=1,Collate=False,Duplex=Simplex,Frompage=0,ToPage=0";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["ReportStyleNum"] = 1012;
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["WorkstationID"] = Environment.MachineName + " 1";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["DateFormat"] = "dd/mm/yyyy";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["NumericFormat"] = ",.";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["ProcessTaskNum"] = "0";
			   ARInvDs.Tables["ARInvFormParam"].Rows[0]["ReportCultureCode"] = "en-GB";
               ARInvDs.Tables["ARInvFormParam"].Rows[0]["ReportCurrencyCode"] = "GBP";
               ARInvDs.Tables["ARInvFormParam"].Rows[0]["ArchiveCode"] = "0";
               ARInvDs.Tables["ARInvFormParam"].Rows[0]["DecimalsGeneral"] = "2";
               ARInvDs.Tables["ARInvFormParam"].Rows[0]["DecimalsCost"] = "5";
               ARInvDs.Tables["ARInvFormParam"].Rows[0]["DecimalsPrice"] = "5";
               ARInvDs.Tables["ARInvFormParam"].Rows[0]["GlbDecimalsGeneral"] = "2";
               ARInvDs.Tables["ARInvFormParam"].Rows[0]["GlbDecimalsCost"] = "5";
               ARInvDs.Tables["ARInvFormParam"].Rows[0]["GlbDecimalsPrice"] = "5";
               ARInv.SubmitToAgent(ARInvDs, "SystemTaskAgent", 0, 0, "Epicor.Mfg.UIRpt.ARInvForm");
	         ARInvDs.Dispose();
	         ARInv = null;
found the problem - document sender setting need changing,.
