Emailing Sales order confirmations
Thanks again...
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> The variables are:
> async as logical
> company as character
> emailFrom as character
> emailTo as character
> emailCC as character
> emailSubject as character
> emailText as character
> emailMimeHeader as character
> and I believe the :U indicates that the preceding can not be translated to other programming languages (Untranslatable)
> --- In vantage@yahoogroups.com, "CarlH" <carl.heeder@> wrote:
> > ?Thanks to you both. I did use Sean's technique and it worked well.
> > Do either of you know what the parameters are used for in the
> > > run SendEmail in mhEmailProc (false,CUR-COMP,mFrom,mTo,mCc,
> > mSubject, mBody,"":U
> > especially the False, the "" and the terminal U:?
> > it worked but I am curious
> > > I'll give it a go. Thanks
> > > --- In vantage@yahoogroups.com, Bill Jackson <fujijapman@> wrote:
> > > >  We're on Vantage 6.10, we do this- we set up a 'BAM' (alert), configured the Order VB Form to include the customer email address, then loop thru the Order to get the info , write everything to the 'email body', very similar to the procedure from Sean.
> > > > --- On Tue, 2/22/11, Sean McDaniel <smcdaniel@> wrote:
> > > > From: Sean McDaniel <smcdaniel@>
> > > > Subject: RE: [Vantage] Emailing Sales order confirmations
> > > > To: vantage@yahoogroups.com, vantage@yahoogroups.com
> > > > Date: Tuesday, February 22, 2011, 2:38 PM
> > > > ÂÂ
> > > > You'd have to do an ABL bpm, essentially calling the email portion from within the 4GL code.
> > > > Once you're in the ABL you can loop through the OrderHed, OrderDtl and OrderRel tables to get all of the pertinant information for the body.
> > > > For carriage return/line feeds use "~n"
> > > > Here is an email example through 4gl...
> > > > define variable mFrom as character.
> > > > define variable mTo as character.
> > > > define variable mCc as character.
> > > > define variable mSubject as character.
> > > > define variable mBody as character.
> > > > define variable mhEmailProc as handle no-undo.
> > > > run Bpm/BpmEmail.p persistent set mhEmailProc.
> > > > for each ttDMRCorAct.
> > > > assign mFrom = <mail from>
> > > > mTo = <mail to>
> > > > mSubject = <subject
> > > > mBody = <body>.
> > > > false,
> > > > CUR-COMP,
> > > > mFrom,
> > > > mTo,
> > > > mCc,
> > > > mSubject,
> > > > mBody,
> > > > "":U
> > > > if valid-handle( mhEmailProc) then delete procedure mhEmailProc.
> > > > leave.
> > > > end.
> > > > ________________________________
> > > > From: vantage@yahoogroups.com on behalf of CarlH
> > > > Sent: Tue 2/22/2011 2:30 PM
> > > > Subject: [Vantage] Emailing Sales order confirmations
> > > > We'd like to email a sales order confirmation to each sales rep when a neew order is entered.
> > > > I thought about doing this from a BPM but cannot figure out how to include all the SO detail info in one email
> > > > Does anybody else ahve an idea?
> > > > [Non-text portions of this message have been removed]
mTo = <mail to>
mSubject = <subject
mBody = <body>.
false,
CUR-COMP,
mFrom,
mTo,
mCc,
mSubject,
mBody,
"":U
leave.
end.
Â
mTo = <mail to>
mSubject = <subject
mBody = <body>.
false,
CUR-COMP,
mFrom,
mTo,
mCc,
mSubject,
mBody,
"":U
leave.
end.
> From: Sean McDaniel <smcdaniel@...>
> ÂÂ
> mTo = <mail to>
> mSubject = <subject
> mBody = <body>.
> false,
> CUR-COMP,
> mFrom,
> mTo,
> mCc,
> mSubject,
> mBody,
> "":U
> leave.
> end.
> > ÂÂ
> > mTo = <mail to>
> > mSubject = <subject
> > mBody = <body>.
> > false,
> > CUR-COMP,
> > mFrom,
> > mTo,
> > mCc,
> > mSubject,
> > mBody,
> > "":U
> > leave.
> > end.
The variables are:
async as logical
> > > ÂÂ
> > > mTo = <mail to>
> > > mSubject = <subject
> > > mBody = <body>.
> > > false,
> > > CUR-COMP,
> > > mFrom,
> > > mTo,
> > > mCc,
> > > mSubject,
> > > mBody,
> > > "":U
> > > leave.
> > > end.
