It wouldn't hurt to go to Progress' site & download the Open Edge Development Progress 4GL Handbook.
That can help with BAQs (and I suppose BPMs - not my thing). The BAQ editor only supports a small subset of the full progress language - but sometimes you get lucky and the handbook will give you a cleaner way to deveop a calculated field.
If you are doing client cusotmizations, you can't go wrong regularly visiting MS' Technet site. (Tons of free .NET code examples & a good self education source... Likely the same re v9 & ADO & C#).
Rob
Rob
--- On Tue, 4/7/09, argonics_mi <bwelch@...> wrote:
Subject: [Vantage] Re: Embedded Dashboard Subscribe troubles
Date: Tuesday, April 7, 2009, 11:36 AM
Bingo! Thank you.
This brings up another point. You have fed me for a day, but what I would really like to do is know how to fish. We have the "Epicor Tools User Guide", but it only got 75% to the solution. You (and the other helpful people on this list) seem to have taken that "next step" in finding resources. I have had poor luck searching the Answer Books, and our Sales Rep mostly recommends on-line classes that other people here have already taken. I have gotten most of these "last mile" answers from this list.
Is there a set of resources I missing?
--- In vantage@yahoogroups .com, "Ross Hughes" <ross.hughes@ ...> wrote:
> Hi Mike,
> You need to go to the filter area of your dashboard query, select the Job
> Num and choose Dashboard Browse from the drop-down menu. I think it is at
> the bottom. Just accept the defaults from the popup menu.
> Then try it again.
> Ross
> -----Original Message-----
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
> argonics_mi
> Sent: Tuesday, April 07, 2009 9:47 AM
> To: vantage@yahoogroups .com
> Subject: [Vantage] Embedded Dashboard Subscribe troubles
> Hello,
> I am trying to add an embedded dash board to a new sheet on a Job Tracker
> customization. I need the current JobHead.JobNum on the dashboard. In
> developer mode, I use the Sheet Wizard to make a new sheet, and on the Add
> Dashboard button, I select my dashboard (JobTrackerLabels) with the
> "Subscribe to UI data (auto Retrieve on publication) " option selected, added
> JobHead.JobNum as a Subscribe Column. In my dashboard, I've tried Tracker
> Views and Queries with their filters using Constant: CurrentJobNumber, but
> no matter what I try, I don't get the current JobNum, and I do get the
> following error window pop up.
> The following application error was encountered:
> Warning- Embedded Dashboard invoked as a Subscriber, but there is no Filter
> defined for the Published columns. Please notify system administrator.
> Can someone tell me how to make the current JobNum available in an embedded
> dashboard?
> Thank you,
> Mike G.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups. yahoo.com/ group/vantage/ files/.
> http://groups. yahoo.com/ group/vantage/ messages
> http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
