Try this out if you are on 5.0
Select:
Part Tracker - PART (Select a part) - press Inv/Purch button.
Note the window wants you to select a plant.
Press CLOSE then press Inv/Purch again.
A different window now appears. It's the one after the select a plant
window.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.00.317, Progress 9.1a
No, I wasn't looking for an Easter egg.
Select:
window.
Patrick Winter
