EmpBasic.LaborRate
Too bad, then Field Security doesn't seem very useful if that's the case.
We use SQL Server, and all reports use stored procedures where I pick exactly what fields are exposed. No one has ODBC connection.
I do not believe that the empbasic table was designed to store anything sensitive, unlike prempmas.
We don't use that field, at any rate.
Sorry I couldn't help.
Sent: Monday, November 17, 2008 8:45:25 AM
Subject: [Vantage] Re: EmpBasic.LaborRate
This might keep it from showing on the Shop Employee Tracker but
probably wouldn't keep the individual labor costs from printing out on
the Production Detail Report. Field Security definitely wouldn't
change anything for the ODBC connection.
--- In vantage@yahoogroups .com, Tony Hughes <thughes281@ ...> wrote:
> would Field Security work for you?
> System Management > Security Maintenance > Field Security, you can
set field by field security.
> ____________ _________ _________ __
> From: adam.whipp <adam.whipp@ ...>
> To: vantage@yahoogroups .com
> Sent: Friday, November 14, 2008 4:10:29 PM
> We are on 8.03.405A
> > what version of Vantage?
> > Sent: Friday, November 14, 2008 9:15:10 AM
> > Thanks for the input Jeff. However, what I am concerned about is
> > people connecting through ODBC for Crystal. If I am not mistaken,
> if
> > we set a user up to connect through ODBC with Cystal, that user can
> > write reports against any table in the database. Is there any way
> to
> > prevent that? I don't know of a way to limit access to certain
> > tables through ODBC. Thanks in advance,
> > Adam
> > --- In vantage@yahoogroups .com, "jplehr" <jlehr@> wrote:
> > > --- In vantage@yahoogroups .com, "adam.whipp" <adam.whipp@ >
> wrote:
> > > > Hello,
> > > > In our company, we keep everyone's actual pay rate in the
> > > > EmpBasic.LaborRate field. This of course is a security risk
> > > because
> > > > anyone can report against the EmpBasic table and find out
> > someone's
> > > > true labor rate. I was wondering how other companies handle
> this
> > > field
> > > > to keep it more secure. I have heard of some companies using
> an
> > > > average based on job function (e.g. all welders could be
> $10.00,
> > > > brazers $11.00, etc). Does anyone have any other suggestions?
> > > Thanks,
> > > > Adam Whipp
> > > Adam,
> > > We use the average practice based on job function. Plus, I don't
> > > have anyone esle with the ability to get to these tables unless
> > they
> > > were a part of the appropriate Security Group.
> > > Jeff
Hello,
EmpBasic.LaborRate field. This of course is a security risk because
anyone can report against the EmpBasic table and find out someone's
true labor rate. I was wondering how other companies handle this field
to keep it more secure. I have heard of some companies using an
average based on job function (e.g. all welders could be $10.00,
brazers $11.00, etc). Does anyone have any other suggestions? Thanks,
Adam Whipp
--- In vantage@yahoogroups.com, "adam.whipp" <adam.whipp@...> wrote:
> Hello,
because
field
> Adam Whipp
Adam,
have anyone esle with the ability to get to these tables unless they
Jeff
people connecting through ODBC for Crystal. If I am not mistaken, if
write reports against any table in the database. Is there any way to
Adam
--- In vantage@yahoogroups.com, "jplehr" <jlehr@...> wrote:
> --- In vantage@yahoogroups.com, "adam.whipp" <adam.whipp@> wrote:
> > Hello,
> because
someone's
> field
> Thanks,
> > Adam Whipp
> Adam,
they
> Jeff
Yes, that is correct Adam. That is why when we installed V8, we did
not give anyone the ODBC drivers. No one in our organization will be
able to write a Crystal Report using ODBC because the drivers are not
on anyone's computer. Everyone will have to use Crystal with BAQ
Reports and hence the Vantage security is already in place for
everyone. When you use BAQ Reports the way Epicor intended, you
never need worry about people seeing report data for which they have
no privileges.
Lynn
if
to
> Adam
> > > Hello,
> > because
> someone's
this
> > field
an
$10.00,
> > Thanks,
> > > Adam Whipp
> > Adam,
> they
> > Jeff
Yes you can. You can create a new database user with its own password and
grant only the tables that are required. I have an ODBCUSER that does not
contain any sensitive tables and I only granted SELECT access to those
tables. That prevents users from "accidentally" updating them if use Access
or some other SQL tool.
The ODBC kit shows how to create a user and which tables are granted access.
You just need to modify this for your needs. You can add several different
database users for your different requirements.
Mark W.
We also use labor rates based on average pay rate by job title.
Keeping labor rates separate from pay rates seems practical and easy
enough to implement. If you have the Payroll Module, only Payroll
Managers that have the proper Payroll Class access should need access
to the real pay rates.
Also, I agree about the security risks of ODBC if you don't have the
ODBCUSER setup with read-only and restricted table access. I wouldn't
let anyone use ODBC as the SYSPROGRESS user.
> Hello,
> Adam Whipp
Adam
--- In vantage@yahoogroups .com, "jplehr" <jlehr@...> wrote:
> --- In vantage@yahoogroups .com, "adam.whipp" <adam.whipp@ > wrote:
> > Hello,
> because
someone's
> field
> Thanks,
> > Adam Whipp
> Adam,
they
> Jeff
We are on 8.03.405A
> From: adam.whipp <adam.whipp@...>
if
to
> Adam
wrote:
> > > Hello,
> > because
> someone's
this
> > field
an
$10.00,
> > Thanks,
> > > Adam Whipp
> > Adam,
> they
> > Jeff
System Management > Security Maintenance > Field Security, you can set field by field security.
We are on 8.03.405A
if
to
> Adam
wrote:
> > > Hello,
> > because
> someone's
this
> > field
an
$10.00,
> > Thanks,
> > > Adam Whipp
> > Adam,
> they
> > Jeff
> We are on 8.03.405A
> if
> to
> > Adam
> wrote:
> > > > Hello,
> > > because
> > someone's
> this
> > > field
> an
> $10.00,
> > > Thanks,
> > > > Adam Whipp
> > > Adam,
> > they
> > > Jeff
