Employee status in Shop Maintenance
Best answer yet!
Much regards to the group for the answer.
Good morning!
Believe it or not somebody keeps inactivating certain employees that are active.
Does it require that user be a member of the payroll class of the active employee to de-activate them?  Also, is there a log somewhere that displays this activity?
Regards.
What version of Epicor are you using?  The interfaces may be different.
Via 9.05 702A, User Security requires someone with "Security Manager" rights to enable or disable the accounts.  Person/Contact and Employee records could be designated to a Finance or Payroll security group (or individual, depending on how your security is set up), but those records (to my knowledge) only control functionality within the system, not access to Epicor directly.
Hope this helps ...
You can view the security thru menu security to see who has access to that form. If you want to track who changes the fields you have to create the BAM to track those field changes, once you do that it will track the changes (who makes the change, when, etc).
On Fri, Mar 20, 2015 at 12:11 PM, sanfranc415@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p><p><span>Good morning!</span></p><p><span><br></span></p><p><span>Believe it or not somebody keeps inactivating certain employees that are active.  </span></p><p><span><br></span></p><p>Does it require that user be a member of the payroll class of the active employee to de-activate them?  Also, is there a log somewhere that displays this activity? </p><p><br></p><p>Regards.</p><p><span><br></span></p><p><span><br></span></p><p></p>
</div>
<div style="color:rgb(255,255,255);min-height:0px;"></div>
Sarah Vareschi ▪ Systems ManagerÂ
Â
NyproMold, Inc.
144 Pleasant St, Clinton, MA 01510 ▪ www.nypromold.com Â
D 978.368.4718Â â–ª F 978.365.4548
Â
Â
Â
This e-mail may contain information which is
confidential or privileged. The information is intended to be for the use of
the individual or entity named above. If you are not the intended
recipient, be aware that any disclosure, copying, distribution or use of the
contents of this e-mail is prohibited. In the event of any error in
transmission, unauthorized recipients are requested to contact the sender
immediately and not to disclose or make use of this information. No
employee or agent is authorized to conclude any binding agreement on behalf of
NyproMold with another party by email without express written confirmation by
NyproMold Offices.
P Please consider the environmental impact of
printing this e-mail.
Okay, so I've added a BAM for EmpBasic and all fields in this table to report a change log, but there is no change log in Shop Employee
Set a menu maintenance security group.  You can also do a Field Security on the Pull Down.
702A
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Friday, March 20, 2015 9:31 AM
To: Vantage List
Subject: Re: [Vantage] Employee status in Shop Maintenance
Good morning!
Regards.
Sarah Vareschi â–ª Systems Manager
NyproMold, Inc.
144 Pleasant St, Clinton, MA 01510 â–ª www.nypromold.com
D 978.368.4718 â–ª F 978.365.4548
This e-mail may contain information which is confidential or privileged. The information is intended to be for the use of the individual or entity named above.  If you are not the intended recipient, be aware that any disclosure, copying, distribution or use of the contents of this e-mail is prohibited.  In the event of any error in transmission, unauthorized recipients are requested to contact the sender immediately and not to disclose or make use of this information.  No employee or agent is authorized to conclude any binding agreement on behalf of NyproMold with another party by email without express written confirmation by NyproMold Offices.
P Please consider the environmental impact of printing this e-mail.
I had to write a BAQ for the employee change log.
On Fri, Mar 20, 2015 at 6:53 PM, Miguel Santillan msantillan@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>
Â
702A
Â
Miguel A. Santillan
Â
To: Vantage List
Â
Â
Â
Â
Â
Good morning!
Â
Believe it or not somebody keeps inactivating certain employees that are active. Â
Â
Does it require that user be a member of the payroll class of the active employee to de-activate them? Also, is there a log somewhere that displays this activity?Â
Â
Regards.
Â
Â
Â
NyproMold, Inc.
Â
Â
Â
</div>
Â
NyproMold, Inc.
Â
Â
Â
NyproMold Offices.
