It is a bug, should not cause you any major problems.
The version is missing code which verifies if the temp table handle is
valid before emptying it.
When the client disconnects from the appserver, it does some clearing
out of any items still left in memory.
Over time, though it could begin to cause issues so until fixed may be
beneficial to restart the appserver per week / month if you see
detrimental performance.
Regards,
Stephen
Of Brian W. Spolarich
Sent: 25 May 2010 15:01
Subject: [Vantage] EMPTY-TEMP-TABLE Messages in Server.log File
I'm seeing a lot of these in my MfgSys803.Server.log since I applied
408B.
[10/05/25@09:07:46.987-0400] P-007248 T-007252 1 AS -- (Procedure:
'StopBL manager/Session.p' Line:4735) You may only invoke
EMPTY-TEMP-TABLE on valid temp-tables. (7352)
Anyone know what they indicate? Is this a problem?
-brian
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@...
<mailto:bspolarich%40advancedphotonix.com>
<mailto:bspolarich@...
<mailto:bspolarich%40advancedphotonix.com> > ~ 734-864-5618 ~
www.advancedphotonix.com <http://www.advancedphotonix.com> __._,_.
Regards,
Stephen
408B.
-brian
Picometrix
bspolarich@...
