End Activity error (MES)
Any chance this user processes records differently than other users?
For example, backing up and then trying to reenter?
Or maybe assigning a new Shop Employee record to this person is worth a try?
I know Vantage userIDs can become unstable.
I've not seen it with a Shop Employee record but...
--- In vantage@yahoogroups.com, "jeppersn" <jepperson@...> wrote:
> I have compared her Shop Employee ID with others in the same department and they are the same. She does not have her own User ID. She does not have a unique password from other shop employees in the same department.
> --- In vantage@yahoogroups.com, Joshua Giese <jgiese@> wrote:
> > Have you compared her Shop Employee ID with the Shop Employee IDs. She would have to have her own UserFile record as well if she has a password different from others. The Employee records directly link UserFile Records for password authentication.
> > Joshua Giese
> > CTO
> > 920.437.6400 Ext. 337
> > Site ID: 27450-E905700B2-SQL64
> > ----- Original Message -----
> > From: "jeppersn" <jepperson@>
> > Sent: Tuesday, April 2, 2013 1:47:17 PM
> > Subject: [Vantage] Re: End Activity error (MES)
> > I'm sorry if I misunderstood or am otherwise confused. I am new to Epicor and am still trying to learn to navigate the system, while simultaneously help other users figure out their problems.
> > I'm not sure if this is the "standard" way of using Vantage, but the way MES is managed at my company is:
> > Each department has one workstation to log their production activity into MES. All of the users share a Windows profile, as well as a Vantage username (i.e.- Art, Screen, Inspection, Shipping, etc.) After logging into the main MES window, each shop employee has their own individual Employee ID that they use to log in and complete job transactions.
> > Again, sorry if this is unclear or if I am not explaining myself sufficiently. The errors are being generated by a shop employee who shares a Vantage username with other shop employees, but has her own unique shop employee ID.
> > --- In vantage@yahoogroups.com , Joshua Giese <jgiese@> wrote:
> > > That is counter to what you said in the previous post " > Multiple other users log in to the same workstation and complete the same types of operations and are not receiving the error.".
> > > How would all of the employees have the same user login, but at the same time have and issue with only certain employees? What I mean by " Is their employee record and user record the same as everyone elses? Is there maybe some security that is not allowing them access to jobs (which would result in no records)?" I am implying the Epicor UserFile and Emp records. Did you take my meaning for Windows Profile?
> > > Joshua Giese
> > > CTO
> > > Sent: Tuesday, April 2, 2013 1:36:41 PM
> > > I've checked that, as well. All of the employees in our Inspection department use the same user profile, so that's not the issue. The shop employee profile for the account creating errors is the same as the profiles for the other shop employees in her department.
> > > > Joshua Giese
> > > > CTO
> > > > Sent: Tuesday, April 2, 2013 1:15:59 PM
> > > > Additionally, I logged in as the "problem user" on my workstation and on one of the jobs that I knew was producing the error and received the same error when I tried to end the activity.
> > > > That said, it seems to be something specific to that user.
> > > > --- In vantage@yahoogroups.com , "b_ordway" <cooner_55421@> wrote:
> > > > > >>other users are not receiving the same error
> > > > > >>when completing the same type of operation
> > > > > Just curious if all the users are sharing MES on the same device?
> > > > > Or if the user gets the error on different devices?
> > > > > --- In vantage@yahoogroups.com , "jeppersn" <jepperson@> wrote:
> > > > > > I have one specific shop employee that is complaining about an error when she attempts to end a labor transaction. I opened a support ticket with Epicor and the support tech indicated that the error is being caused by a problem in the resource group's input or output warehouse for the operation. While this might be the case, I don't think it is because other users are not receiving the same error when completing the same type of operation and the user that is getting the error doesn't get it all the time (it's intermittent and even on jobs where it does occur, it will sometimes go through if she attempts to end the activity again).
> > > > > > Any help would be greatly appreciated.
> > > > > > Jay
> > > > > > __________________________________________________________
> > > > > > There error window says:
> > > > > > Exception caught in:
> > > > > > Epicor.Mfg.BO.Labor
> > > > > > Error Detail
> > > > > > Message: Unexpected error - see appserver logs.
> > > > > > Type: Error
> > > > > > Program:
> > > > > > Method:
> > > > > > Table:
> > > > > > Row:
> > > > > > Field:
> > > > > > Stack Trace
> > > > > > at Epicor.Mfg.Proxy.LaborImpl.Update (LaborDataSet ds)
> > > > > > at Epicor.Mfg.UI.Adapters.LaborAdapter.Update()
> > > > > > at Epicor.Mfg.UI.App.EndActivityEntry.EndActTransaction.Update()
> > > > > > The section of the Appserver log in question follows (Epicor tech support has stated that the "** No JobProd record is available. (91)" is the section that indicates an error with the resource group's input or output warehouse.):
> > > > > > [13/04/01@13:55:55.507-0500] P-006740 T-006744 1 AS -- (Procedure: 'as/activate.p' Line:380) Incoming call from DELL14:0
> > > > > > [13/04/01@13:55:55.507-0500] P-006740 T-006744 4 AS AS -- TRACE: SINGLE-RUN Procedure bo/Labor.p:Update START (8458)
> > > > > > [13/04/01@13:55:55.554-0500] P-006740 T-006744 1 AS -- ** No JobProd record is available. (91)
> > > > > > [13/04/01@13:55:55.554-0500] P-006740 T-006744 1 AS -- ** 4GL Debug-Alert Stack Trace **
> > > > > > [13/04/01@13:55:55.554-0500] P-006740 T-006744 1 AS -- --> CreatePartAlloc lib/pwipmtlq.p (E:\epicor\mfgsys803\Server\lib\pwipmtlq.r) at line 2014
> > > > > > [13/04/01@13:55:55.554-0500] P-006740 T-006744 1 AS -- FindFinalLoc lib/pwipmtlq.p (E:\epicor\mfgsys803\Server\lib\pwipmtlq.r) at line 2520
> > > > > > [13/04/01@13:55:55.554-0500] P-006740 T-006744 1 AS -- lib/pwipmtlq.p (E:\epicor\mfgsys803\Server\lib\pwipmtlq.r) at line 1689
> > > > > > [13/04/01@13:55:55.554-0500] P-006740 T-006744 1 AS -- createMtlqPwip bo/Labor.p (E:\epicor\mfgsys803\Server\bo\Labor.r) at line 18855
> > > > > > [13/04/01@13:55:55.554-0500] P-006740 T-006744 1 AS -- laborDtlAfterUpdate bo/Labor.p (E:\epicor\mfgsys803\Server\bo\Labor.r) at line 22383
> > > > > > [13/04/01@13:55:55.554-0500] P-006740 T-006744 1 AS -- LaborDtlUpdateRow bo/Labor.p (E:\epicor\mfgsys803\Server\bo\Labor.r) at line 6581
> > > > > > [13/04/01@13:55:55.554-0500] P-006740 T-006744 1 AS -- LaborDtlUpdate bo/Labor.p (E:\epicor\mfgsys803\Server\bo\Labor.r) at line 6331
> > > > > > [13/04/01@13:55:55.554-0500] P-006740 T-006744 1 AS -- Update bo/Labor.p (E:\epicor\mfgsys803\Server\bo\Labor.r) at line 9661
> > > > > > [13/04/01@13:55:55.554-0500] P-006740 T-006744 4 AS AS -- TRACE: SINGLE-RUN Procedure END ERROR. (8458)
> > > > [Non-text portions of this message have been removed]
Jay
__________________________________________________________________
Epicor.Mfg.BO.Labor
Error Detail
Type: Error
Program:
Method:
Table:
Row:
Field:
Stack Trace
> Jay
> Epicor.Mfg.BO.Labor
> Error Detail
> Type: Error
> Program:
> Method:
> Table:
> Row:
> Field:
> Stack Trace
> > Jay
> > Epicor.Mfg.BO.Labor
> > Error Detail
> > Type: Error
> > Program:
> > Method:
> > Table:
> > Row:
> > Field:
> > Stack Trace
Joshua Giese
CTO
> > Jay
> > Epicor.Mfg.BO.Labor
> > Error Detail
> > Type: Error
> > Program:
> > Method:
> > Table:
> > Row:
> > Field:
> > Stack Trace
> Joshua Giese
> CTO
> From: "jeppersn" <jepperson@...>
> > > Jay
> > > Epicor.Mfg.BO.Labor
> > > Error Detail
> > > Type: Error
> > > Program:
> > > Method:
> > > Table:
> > > Row:
> > > Field:
> > > Stack Trace
Joshua Giese
CTO
> Joshua Giese
> CTO
> > > Jay
> > > Epicor.Mfg.BO.Labor
> > > Error Detail
> > > Type: Error
> > > Program:
> > > Method:
> > > Table:
> > > Row:
> > > Field:
> > > Stack Trace
> Joshua Giese
> CTO
> > Joshua Giese
> > CTO
> > > > Jay
> > > > Epicor.Mfg.BO.Labor
> > > > Error Detail
> > > > Type: Error
> > > > Program:
> > > > Method:
> > > > Table:
> > > > Row:
> > > > Field:
> > > > Stack Trace
Joshua Giese
CTO
> Joshua Giese
> CTO
> > Joshua Giese
> > CTO
> > > > Jay
> > > > Epicor.Mfg.BO.Labor
> > > > Error Detail
> > > > Type: Error
> > > > Program:
> > > > Method:
> > > > Table:
> > > > Row:
> > > > Field:
> > > > Stack Trace
> Joshua Giese
> CTO
> > Joshua Giese
> > CTO
> > > Joshua Giese
> > > CTO
> > > > > Jay
> > > > > Epicor.Mfg.BO.Labor
> > > > > Error Detail
> > > > > Type: Error
> > > > > Program:
> > > > > Method:
> > > > > Table:
> > > > > Row:
> > > > > Field:
> > > > > Stack Trace
