Our Enterprise Search isn’t available and isn’t working. It has probably been this way since our uplift from 9 but no one really noticed until now when someone said “It would be great if we could search Epicor for specific things”.
When I try to register a search server, I can ping the server but it fails when validating the port. Port 9098 IS opened in the firewall by the way. I do notice that the Epicor Search Indexer does not even exist in services. I have the extension successfully deployed. If I click Create Search Index, it also fails which is not unexpected since I have the issue above. Any help would be greatly appreciated.
Do you have multiple Applications Servers, i.e. Live, Pilot, test? You can only install Enterprise Search on one application on a server, usually Live. Verify in Application Server Configuration for each application. If so, uninstall on all applications servers and reinstall on only one.
In the Epicor Admin Console > Application Server Configuration. File > Uninstall > Enterprise Search.
Then close Epicor Admin Console and come back in again and run Application Server Configuration.
Go to Extensions > Enterprise Search > File > New > Enterprise Search.
I have a single application server running Live, Test and Pilot…
The new button is grayed out for Enterprise Search and the list under File → New are all gray.
So is it installed in all, Live, Test and Pilot? If so do an Uninstall of ES on each one. Then only do a New Install on one of them, i.e. Live.
If you want ES on all applications you would create separate ES Indexes for each one.
Chris, I tried calling you but left a voicemail. Please create a support case in EpicCare and we can get back to you to get this installed and working. Thanks.
Aeron,
I think you left me a voice mail but it got deleted. My bad.
By the way, even after server updates and reboots, those items are still grayed out.
It looks easy enough but does it pick up the Application Servers and such automatically or do I have to set it all up again? And this will not effect user connectivity?
Also, c:\epicor\ERP10\ERP10.2.400.0\SupplementalInstalls\Administration\ApplicationServerManager does not exist. That SupplementalInstalls folder is empty…
