You need to have the ODBC configured on your Vantage Server, Tech can help
you with step by step on that, Next each machine that is going to run the
reports using ODBC is configured, again Tech can help with that. Once set up
and connecting, open your report in Crystal and create a sub report using
the table that contains your data, suppress or delete all header and footer
lines, link to the main report using the appropriate data field. Place the
field in the appropriate location and you are done.
Shirley
Sent: Tuesday, March 18, 2003 7:55 AM
Subject: RE: [Vantage] Entry Person Field
Sounds good, but how do you do that? Remember I am an accountant doing an
sys admin job ---- please reply in simple English! (LOL)
Sent: Tuesday, March 18, 2003 7:46 AM
If you have ODBC installed, (automatic for 5.0 and beyond) you can make a
single field subreport and pull that information over. We use this approach
to print material certs on the packing slips and a host of other items.
Shirley Graver
Sys Admin
Rubber Associates
Sent: Tuesday, March 18, 2003 7:17 AM
I had the same problem with the job traveler. I called support and they
told me that just because you can see the field in the table, doesn't
mean it is available in the crystal report. So you are stuck. We
wanted the rev level of our material requirements to print on the
traveler, I don't understand why all fields are not available. Maybe
someone out there has a trick up their sleeve.
Kathy Hambleton
Sent: Monday, March 17, 2003 6:15 PM
Subject: [Vantage] Entry Person Field
HELP!!!!
I have been asked several times to put the "entry person" field on
the SO acknowledgement form. I can see it is part of the ORDHEAD
table, but I do not see it in the list when I open the report in
Crystal! Any help you can give would be great!
Thanks!
PS -- I have not been to any Crystal classes so plese give lots of
details whe you respond.
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/files/.> > >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/messages> > >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
<http://groups.yahoo.com/group/vantage/links> > >
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > >
Yahoo! Groups Sponsor
ADVERTISEMENT
http://rd.yahoo.com/M=246920.2960106.4328965.2848452/D=egroupweb/S=17050071
<http://rd.yahoo.com/M=246920.2960106.4328965.2848452/D=egroupweb/S=17050071
http://www.gotomypc.com/u/tr/yh/cpm/grp/300_yh1/g22lp?T
<http://www.gotomypc.com/u/tr/yh/cpm/grp/300_yh1/g22lp?T>
< http://www.gotomypc.com/u/tr/yh/cpm/grp/300_yh1/g22lp?T
<http://www.gotomypc.com/u/tr/yh/cpm/grp/300_yh1/g22lp?T> >
arget=mm/g22lp.tmpl>
http://us.adserver.yahoo.com/l?M=246920.2960106.4328965.2848452/D=egroupmai
<http://us.adserver.yahoo.com/l?M=246920.2960106.4328965.2848452/D=egroupmai
Your use of Yahoo! Groups is subject to the Yahoo!
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> <
Terms of Service.
http://rd.yahoo.com/M=245314.3072841.4397732.2848452/D=egroupweb/S=17050071
<http://rd.yahoo.com/M=245314.3072841.4397732.2848452/D=egroupweb/S=17050071
<http://www.netbizideas.com/yheb42> >
http://us.adserver.yahoo.com/l?M=245314.3072841.4397732.2848452/D=egroupmai
<http://us.adserver.yahoo.com/l?M=245314.3072841.4397732.2848452/D=egroupmai
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
83:HM/A=1495890/R=0/*http://www.netbizideas.com/yheb42%20>
l/S=:HM/A=1495890/rand=633370795>
<http://docs.yahoo.com/info/terms/> Terms of Service.
Shirley
Shirley Graver
Sys Admin
Rubber Associates
Kathy Hambleton
HELP!!!!
Thanks!
ADVERTISEMENT
>83:HM/A=1481659/R=0/*
>l/S=:HM/A=1481659/rand=211268950>
Terms of Service.
>83:HM/A=1495890/R=0/* http://www.netbizideas.com/yheb42
>l/S=:HM/A=1495890/rand=588334967>
