Thanks for the feedback. Good to see they are moving onto a newer tech!
--- In vantage@yahoogroups.com, "peter_gribanov" <peter_gribanov@...> wrote:
> It uses WSE 3.0. You still able to use WSE in Visual Studio 2008/2010 - see MSDN, for example, http://msdn.microsoft.com/en-us/library/ms819938.aspx describes how to create a WSE service client that uses username token authorization. Hint: you can use wsewsdl tool for proxy class generation as described here: http://msdn.microsoft.com/en-us/library/aa529578.aspx
> Starting from 9.05.601 (AFAIK) Epicor provides ability to expose functionality via WCF serices which are pretty modern.
