Epcior 9 Print 2 copies of check to separate trays?
Kurt,
I don't know of a way to control Tray settings within the report itself, but I'll tell you that we have two check styles - one for the real check, and one for the 'copy' that removes the signature and replaces it with "File Copy".
Then when we print checks, we simply print he first style and when the printer dialog comes up - choose the right tray.
Then we 'reprint' checks using the second style and the other tray.
it's not perfect but it does do exactly what we wanted and is only a few more clicks.
Hope that helps,
Mike
Does anyone know how to set Epicor to print 2 copies of checks to different trays on a printer?
Tray 1 would be the actual check
Tray 2 would be a copy on plain paper.
We have an HP LaserJet 2430.
I've looked at all the settings -Printer and Epicor and Crystal- and can't figure out how to do it.
Ideas??
