EPI Weaving install error
Hello Does anyone have a script I can use to change a pending workbench converstion to 100% so i can log back into our pilot enviroment to re run solution workbench
If it’s pending can’t you run it? It should prompt you to run it when you try to login
I’ve found that if it won’t run one or two it’s usually a permissions issue - log in as the manager account or service account instead.
In my case we use Windows authentication, but if you shift-rightclick the shortcut you get a context menu option to run as a different user.
