Is it possible to set a background image to an EpiButton? If so, does anybody knows how to?
I have already tried the "epiButton1.BackgroundImage = Image.File(@“filepath”); but it is not working…
I also tried the "epiButton1.Image = Image.File(@“filepath”); but it is still not working…
I’ve never done this but when you set the background image, did you also set UseDefaultAppStyling = false?
Hi Chris, yes I have… actually I´m not able to save the custom due to errors in the code. when I test the written code some errors are shown. will paste them here once I get to the office.
Sounds good. Also I read that there may be an ImageList property you can set and the you pick an ImageIndex.
Also there is this: Button1.Appearance.Image = System.Drawing.Image.FromFile(“C:\test.jpg”).
Chris_Conn:
well well well… I don´t know why but today when I came in and test it, trying to duplicate the error messages, it start working… the working code is:
`later today will give it a try with the
sentence and will update you
AndrewM
(Andrew)
November 22, 2018, 9:20pm
6
Did you manage to get this to work with correct scale of the image? When I add an image, it is scaled to only a few pixels.
Hi Andrew,
unfortunately no, I was not able to. it was not working as expected and I give up on that.
AndrewM
(Andrew)
December 12, 2018, 11:49pm
8
Thanks for the response… at least I’m not the only one.
Chris_Conn
(Chris Conn)
December 13, 2018, 12:50am
9
epiButtonC21.Appearance.ImageBackgroundStyle = Infragistics.Win.ImageBackgroundStyle.Centered;
epiButtonC21.Appearance.Image = Image.FromFile(@"c:\BellaNapoliSnip2Photos.png");
epiButtonC21.ImageSize = new System.Drawing.Size(epiButtonC21.Width, epiButtonC21.Height);
jstephens
(Jason Stephens)
December 13, 2018, 7:53pm
10
I couldn’t get the image to center properly using the ImageBackgroundStyle, but ImageHAlign and ImageVAlign worked.
epiButtonC1.Appearance.ImageHAlign = Infragistics.Win.HAlign.Center;
epiButtonC1.Appearance.ImageVAlign = Infragistics.Win.VAlign.Middle;
Also, this will resize the image to fill the button while maintaining the image’s aspect ratio.
double ratioX = (double) epiButtonC1.Width / (double) img.Width;
double ratioY = (double) epiButtonC1.Height / (double) img.Height;
// use whichever multiplier is smaller
double ratio = ratioX < ratioY ? ratioX : ratioY;
// get the new height and width
int newWidth = Convert.ToInt32(img.Width * ratio);
int newHeight = Convert.ToInt32(img.Height * ratio);
epiButtonC1.ImageSize = new System.Drawing.Size(newWidth, newHeight);
AndrewM
(Andrew)
December 16, 2018, 10:52pm
11
Fantastic!
I also had to use the ImageHAlign and ImageVAlign proporties to correctly align the image.
