EpiCombo problem: cannot find columm name Sales
well I am working with 305.
I tried the two phase method you suggested and it did work when it was
not bound.
once I bound it to a field (Jobhead.shortchar05) I got the same error
message.
thanks for your help, but I guess it means that they have a bug with
regular combos that are bound to fields and are using existing BO
(unlike hard coded values).
BTW, I also think that this way of using combos is not that common
anyhow. either you need BOs and then you would probably end up using
the adapter (EpiUltraCombo) or you need hard coded values...which is
again not this case.
Amir
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...> wrote:
> Amir,
> I just tested it and it worked on 403D. Create a new one
> don't bind to anything to start with and test again.
> Also don't forget to populate Display member and DescColumnName
> Of baruch.amir
> Sent: Wednesday, December 19, 2007 11:32 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: EpiCombo problem: cannot find columm name Sales
> thanks Stephen,
> I tried changing the EpiTableName value to SalesRepList but I'm still
> getting the same error message.
> Cannot find column SalesRepCode
> thanks,
> Amir
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Stephen Edginton" <stephene@> wrote:
> > Amir,
> > The EpiTableName should be SalesRepList if your using
> > the ListDataSet.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of baruch.amir
> > Sent: Monday, December 17, 2007 4:16 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] EpiCombo problem: cannot find columm name Sales
> > Hi,
> > I ran into problems when trying to attach an EpiCombo control to the
> > JobEntry Form. this control was meant to pull values from the SalesRep
> > table and write the SalesRepCode to a UD field in the JobHeader table.
> > Now I know we could use EpiUltraCombo and assocaite an adaptor which
> is
> > what I did eventually (and it worked!) but I started with using an
> > EpiCombo control and failed and I'm really interested in understanding
> > the reason for that.
> > so I have detaield the definitions I used below as well as the erros
> > message I got.
> > Does anyone have a clue what I may be doing wrong?
> > Amir
> > control definitons
> > EpiBoName: SalesRep
> > EoiColumn[0]: SalesRepCode
> > EoiColumn[1]: Name
> > EpiDataSetMode:ListDataSet
> > EpiSort: Empty
> > EpiTableName: SalesRep
> > SearchFilter:Empty
> > ValueMember:SalesRepCode
> > Error Message:
> > See the end of this message for details on invoking
> > just-in-time (JIT) debugging instead of this dialog box.
> > ************** Exception Text **************
> > System.IndexOutOfRangeException: Cannot find column SalesRepCode.
Hi,
Now I know we could use EpiUltraCombo and assocaite an adaptor which is
message I got.
Amir
control definitons
EpiBoName: SalesRep
EoiColumn[1]: Name
EpiSort: Empty
SearchFilter:Empty
Error Message:
Amir,
the ListDataSet.
Of baruch.amir
Hi,
message I got.
Amir
control definitons
EpiBoName: SalesRep
EoiColumn[1]: Name
EpiSort: Empty
SearchFilter:Empty
Error Message:
thanks Stephen,
thanks,
Amir
> Amir,
> the ListDataSet.
> Of baruch.amir
> Hi,
> message I got.
> Amir
> control definitons
> EpiBoName: SalesRep
> EoiColumn[1]: Name
> EpiSort: Empty
> SearchFilter:Empty
> Error Message:
Amir,
Of baruch.amir
thanks Stephen,
thanks,
Amir
> Amir,
> the ListDataSet.
Behalf
> Of baruch.amir
> Hi,
is
> message I got.
> Amir
> control definitons
> EpiBoName: SalesRep
> EoiColumn[1]: Name
> EpiSort: Empty
> SearchFilter:Empty
> Error Message:
