EpiCombo via a UserCode on a standard field
I’ve used User Codes as the source for EpiCombo for UD fields but I’m trying to use it for the Part.MtlBurRate. We’ve got 3 and the teams wants a pull down so the values aren’t manually entered.
Is there any way to map a User Code to a standard field for this purpose?
I got it to work via a BAQCombo
Update: Also got the epiCombo to work. Problem was on numeric fields to
match the number of decimals, so in our case it was n.nnnn. I added the
extra zeros and it worked as it should.
