Epicor 10 -Knitec
Hello,
I have a question regarding the knitec. if we convert Epicor 10.2 to Knitec, the current business object dll in Epicor 10.2 such as Erp.Part.dll can be reused or we have to redo everything for our customization.
thanks a lot,
Eddy
@eqiu The dll will change. You are already in a rest capably version. I would recommend making the change to rest vs dll so you are future proofing rather than just updating.
thanks a lot.
Hello Greg,
the problem for the rest is it seems less functions available rather than dll. some module like job, serial numbers, it has not full functions if you compare with job and serial number dll.
regards,
Eddy
What are you trying to do Eddy? Which functions can you not find?
REST comes in two flavors: OData and RPC. The RPC version has the exact same methods as the Business Objects you are used to.
@eqiu Wow @Mark_Wonsil is not kidding. I had not really looked at the custom methods, but comparing it to my BO reference it had the same list from what I could see. Change the definition in the upper right to custom methods.
Even your own custom routines can be put into a ubaq or function and called from another program.
