Epicor 9.04.504 Printing Errors
Thanks Mark!
That seems to be working for us.
Troy
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark Wonsil
Sent: September-22-09 4:12 AM
Subject: RE: [Vantage] Re: Epicor 9.04.504 Printing Errors
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> wrote:
> I've had the same issue, it hasn't prevented us from printing - I have
> reported it and not heard back.
This issue re-appeared in 9.03.504 for us too. Epicor may have discovered
the solution:
It looks like styles added or modified in V8.xx and upgraded to E9 have a
problem. Try the following workaround:
1. System Management > Company Maintenance > Report Style
2. Enter in the ReportStyle that you are receiving the error on.
3. For each Report Report Style, Uncheck the "Valid" checkbox.
4. Save.
5. For all of the above Report Style; check the "Valid" checkbox and
Save.
You should now be able to Print/Preview the report without error.
You may have to reset your Default Styles after doing this.
Mark W.
I was getting this error about violating DB constraints whenever I print
anything but not regularly:
Table: SysRptLst
DCDUserID=''
WorkStationID=''
CreateDate='(null)'
CreateTime='0' RecSeq='0'
RowIdent='0x0000000000d10b8e':
Column 'CreateDate' does not allow DBNull.Value
The RowIdent changes but it just pops up every so often. If I click through
a few of them, I'll get my preview or print out. I've found one other user
getting it, are there any others?
Thanks!
Mark W.
Hi Mark,
I'm currently working on this problem too. Although in this case it's
not happening randomly, it will do it every time I run a "stock status"
report.
Brian Johnson -- Epi-Center <http://epi-ctr.com>
Developer | direct: 413-531-2859
> Table: SysRptLst
> DCDUserID=''
> WorkStationID=''
> CreateDate='(null)'
> through
> Thanks!
> Mark W.
Brian /Mark -
Support had me re-run conversions 100 & 130 and this seems to have
solved this problem. I don't understand why this worked.
Dan Sirow
Independent Components Corp.
--- In vantage@yahoogroups.com, Brian Johnson <bjohnson@...> wrote:
> Hi Mark,
status"
> report.
print
> > Table: SysRptLst
> > DCDUserID=''
> > WorkStationID=''
> > CreateDate='(null)'
> > through
other user
> > Thanks!
> > Mark W.
I had run conversion 130 yesterday before leaving, but didn't have time
to test it. This did fix this error for me as well.
dansirow wrote:
> Brian /Mark -
> Dan Sirow
> _,___
I tried this fix and unfortunately it didn't fix the issue for us.
I just upgraded my test server to 504A and the issue came back. I re-ran
100, 130, 140, and 150 and it went away. I'm not sure which one fixed the
problem.
Mark W.
Ire-ran coversion programs 100, 130, 140 & 150 again and it didn't solve the issue for us.
Troy
> problem.
> Mark W.
Would you please repost the error message that you're getting?
Mark W.
Mark,
Here is the error message.
Troy
Error Detail
Failed to enable constraints. One or more rows contain values violating non-null, unique, or foreign-key constraints.
Table: SysRptLst
DCDUserID='' WorkStationID='' CreateDate='(null)' CreateTime='0' RecSeq='0' RowIdent='0x000000000168318d': Column 'CreateDate' does not allow DBNull.Value.
Stack Trace
at Epicor.Mfg.Pro.Convert.copyDataTable(DataTable sourceDT, DataTable targetDT)
at Epicor.Mfg.Pro.Convert.ToDataSet(DataSet tempDataSet, DataSet ds)
at Epicor.Mfg.Proxy.ReportMonitorImpl.GetRowsKeepIdleTime(String whereClauseSysRptLst, Int32 pageSize, Int32 absolutePage, Boolean& morePages)
at Epicor.Mfg.UI.Adapters.ReportMonitorAdapter.GetRowsKeepIdleTime(SearchOptions opts, Boolean& MorePages)
Inner Exception
Inner Stack Trace
at System.Data.DataSet.FailedEnableConstraints()
at System.Data.DataSet.EnableConstraints()
at System.Data.DataSet.set_EnforceConstraints(Boolean value)
at System.Data.DataTable.EndLoadData()
> Thanks,
> Mark W.
Hi Troy,
Which report are you trying to run when you get this error message?
CHRIS
Sent: Monday, 17 August, 2009 19:41:03
Subject: [Vantage] Re: Epicor 9.04.504 Printing Errors
Â
Mark,
Troy
Error Detail
Table: SysRptLst
DCDUserID='' WorkStationID= '' CreateDate=' (null)' CreateTime=' 0' RecSeq='0' RowIdent='0x0000000 00168318d' : Column 'CreateDate' does not allow DBNull.Value.
Stack Trace
at Epicor.Mfg.Pro. Convert.copyData Table(DataTable sourceDT, DataTable targetDT)
at Epicor.Mfg.Pro. Convert.ToDataSe t(DataSet tempDataSet, DataSet ds)
at Epicor.Mfg.Proxy. ReportMonitorImp l.GetRowsKeepIdl eTime(String whereClauseSysRptLs t, Int32 pageSize, Int32 absolutePage, Boolean& morePages)
at Epicor.Mfg.UI. Adapters. ReportMonitorAda pter.GetRowsKeep IdleTime( SearchOptions opts, Boolean& MorePages)
Inner Exception
Inner Stack Trace
at System.Data. DataSet.FailedEn ableConstraints( )
at System.Data. DataSet.EnableCo nstraints( )
at System.Data. DataSet.set_ EnforceConstrain ts(Boolean value)
at System.Data. DataTable. EndLoadData( )
> Thanks,
> Mark W.
Chris,
This error occurs on all reports but it doesn't happen every time. Typically it will happen once every ten times.
Troy
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Hi Troy,
> Thanks,
> CHRIS
> From: troy.richman <troyr@...>
> Â
> Mark,
> Thanks,
> Troy
> Error Detail
> Table: SysRptLst
> Stack Trace
> Inner Exception
> Inner Stack Trace
> > Thanks,
> > Mark W.
Is there anyone else having similar issues to this in 504?
We are due to upgrade from 503B to 504 but we have just managed to get all of our reports working properly in 503B - I dont want it to be a upgrade that causes more problems.
Were you on 503B before?
If so has anything stopped working in 504 that was working in 503B?
Sent: Tuesday, 18 August, 2009 15:12:39
Â
Chris,
Troy
--- In vantage@yahoogroups .com, Chris Thompson <chriselectrix@ ...> wrote:
> Hi Troy,
> Thanks,
> CHRIS
> ____________ _________ _________ __
> To: vantage@yahoogroups .com
> Â
> Mark,
> Thanks,
> Troy
> Error Detail
> Table: SysRptLst
> Stack Trace
> Inner Exception
> Inner Stack Trace
> > Thanks,
> > Mark W.
Chris,
We were running 503B previously.
This error does not prevent us from printing and Epicor support have been unable to reproduce the issue and claim it is our environment.
Troy
> Â
> Chris,
> Thanks,
> Troy
> > Hi Troy,
> > Thanks,
> > CHRIS
> > From: troy.richman <troyr@>
> > Â
> > Mark,
> > Thanks,
> > Troy
> > Error Detail
> > Table: SysRptLst
> > Stack Trace
> > Inner Exception
> > Inner Stack Trace
> > > Thanks,
> > > Mark W.
Has anyone who had this problem solved it? Does anyone else still have this problem printing with 9.04.504?
Thanks for info.
Dan
--- In vantage@yahoogroups.com, "troy.richman" <troyr@...> wrote:
> Chris,
> Troy
> > Â
> > Chris,
> > Thanks,
> > Troy
> > > Hi Troy,
> > > Thanks,
> > > CHRIS
> > > Â
> > > Mark,
> > > Thanks,
> > > Troy
> > > Error Detail
> > > Table: SysRptLst
> > > Stack Trace
> > > Inner Exception
> > > Inner Stack Trace
> > > > Thanks,
> > > > Mark W.
Dan,
We still have this issue and have not been able to resolve it to date.
We are currently running 9.04.504b.
Troy
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of dansirow
Sent: September-10-09 12:26 PM
Thanks for info.
Dan
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "troy.richman" <troyr@...> wrote:
> Chris,
> Troy
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Chris Thompson <chriselectrix@> wrote:
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Chris,
> > Thanks,
> > Troy
> > > Hi Troy,
> > > Thanks,
> > > CHRIS
> > > Mark,
> > > Thanks,
> > > Troy
> > > Error Detail
> > > Table: SysRptLst
> > > Stack Trace
> > > Inner Exception
> > > Inner Stack Trace
> > > > Thanks,
> > > > Mark W.
Of Troy Richman
Sent: Thursday, September 10, 2009 3:29 PM
Dan,
Troy
Behalf Of dansirow
Thanks for info.
Dan
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> Chris,
> Troy
Alison Levy | IT Manager | Mats Inc.
dir: 781-573-0291 | cell: 781-964-1698 | fax: 781-232-5191
alevy@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
> > Chris,
> > Thanks,
> > Troy
wrote:
> > > Hi Troy,
message?
> > > Thanks,
> > > CHRIS
> > > Mark,
> > > Thanks,
> > > Troy
> > > Error Detail
> > > Table: SysRptLst
> > > Stack Trace
DataTable targetDT)
ds)
Boolean& morePages)
> > > Inner Exception
> > > Inner Stack Trace
DataTable targetDT
> > > > Thanks,
> > > > Mark W.
Same here. 504B has brought us a slew of new issues:
- Configurator takes ten minutes to finish a Get Details after the Input
Phase
- Can't invoice Sales Kits or Serialized Parts
- Can't put multiple G/L lines on a AP Voucher
- Various printing issues including this one
504A breaks Mass Issue if you don't have AMM.
Mark W.
We just put 504B on a test machine so I havent done much testing yet, but all of our parts are serialized. What happens when you try to invoice a serialized part? Is the error during Get Shipments in AP Invoice Entry?
Date: Thursday, September 10, 2009, 7:46 PM
Â
Phase
Mark W.
I was out of the office today so I didn't see it first hand - I just got a
bazillion emails and one of them said that she can't print Invoices with
Sales Kits on them and JOBS won't close if they have Serial Numbers on them.
The person who closes jobs also invoices, so I got the two mixed up in my
previous email. Sorry about that.
The other Mark W.
