Epicor 9.05.602A Install on Windows 7
Agreed,
Login as a domain admin and run the install in admin mode.
Works fine on both 32 and 64 bit installs of windows 7 here.
On Mon, 21 Feb 2011 15:26:42 -0500
Waffqle <waffqle@...> wrote:
I'd double check the permissions. Epicor does work fine
on Windows 7, but 7
is a bit pickier about security and such.
How are you performing the install?
On Mon, Feb 21, 2011 at 2:22 PM, Jennifer
<Jennifer.Lisser@...>wrote:
> We are trying to install Epicor 9.05.602a on a Windows 7
>PC and are getting
> the error "The file \\.....\config\mfgsys.pf could not be
>opened". We can
> navigate to that file off the Windows 7 PC and the file
>is not marked read
> only. We did try to install as an admin on the PC as
>well, same error. This
> install has worked on many other PCs, but those were all
>XP. Anyone else run
> across this and/or know how to fix it?
> Thanks!
> Jenn Lisser
> Dorner Mfg. Corp.
Useful links for the Yahoo!Groups Vantage Board are: (
Note: You must have already linked your email address to
a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for
Report Builder and Crystal Reports and other 'goodies',
please goto: http://groups.yahoo.com/group/vantage/files/.
(3) To view links to Vendors that provide Vantage
services goto:
http://groups.yahoo.com/group/vantage/linksYahoo! Groups
Links
We are trying to install Epicor 9.05.602a on a Windows 7 PC and are getting the error "The file \\.....\config\mfgsys.pf could not be opened". We can navigate to that file off the Windows 7 PC and the file is not marked read only. We did try to install as an admin on the PC as well, same error. This install has worked on many other PCs, but those were all XP. Anyone else run across this and/or know how to fix it?
Thanks!
Jenn Lisser
Dorner Mfg. Corp.
I'd double check the permissions. Epicor does work fine on Windows 7, but 7
> Thanks!
> Jenn Lisser
> Dorner Mfg. Corp.
