Epicor 9.05.700 - Solution Manager
When you try to restore style sheets for reports, it also may only copy one of the style sheets, but the same as the auto print, they are pretty easy to just type in.
Sigfredo.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of b_ordway
Sent: Thursday, April 04, 2013 4:21 PM
Subject: [Vantage] Re: Epicor 9.05.700 - Solution Manager
For the most part I think Solution Manager is working much better in 9.05.700 than any of the previous versions.
But I still ran into a few issues last time I used it.
Here are the two issues that come to mind now:
1 - Dropped Auto-Print info for Report Data Definitions and BAMs.
--- Not a huge deal, I just manually re-enter.
2 - Partial writes of related files for BAQ reports and Dashboards. This was enough of a problem that I finally switched back to export/import for BAQ reports and Dashboards for now.
Sometimes a solution install resulted is orphan record(s).
It was a known issue when I contacted Epicor & they did send me scripts to clean some out some types of orphans (but not all). I never could determine why some would fail.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Winter, Patrick" <pjw@...> wrote:
> Better yet is anyone using Solution Manager to move all
> BAQs, Customizations, Menu Additions, BAQ Reports, Quick Searches, Dashboards, BAMs, User Codes etc….
> from Test to Live?
> Patrick Winter
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of Joshua Giese
> Sent: Thursday, April 04, 2013 10:41
> Subject: Re: [Vantage] Epicor 9.05.700C - Report Data Definitions
> Not sure what version you are on, but I have used the Solution Manager in System Management with some success on that
> Joshua Giese
> CTO
> 920.437.6400 Ext. 337
> Site ID: 27450-E905700B2-SQL64
> From: "Bill Turgeon" <bturgeon@... <mailto:bturgeon%40cotorelay.com <mailto:bturgeon@...%20%3cmailto:bturgeon%40cotorelay.com> > >
> To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Sent: Thursday, April 4, 2013 10:40:09 AM
> Subject: [Vantage] Epicor 9.05.700C - Report Data Definitions
> Can a customized RDD be exported to in order to move from Test to Live?
> I don't see where this is an option.
> Regards,
> Bill Turgeon
> Director, Information Technology
> Coto Technology, Inc.
> 66 Whitecap Drive
> North Kingstown, RI 02852
> Ph: 401-583-7223
> Cell: 401-368-9938
> Fax: 401-942-0920
> E-mail: bturgeon@... <mailto:bturgeon%40cotorelay.com> <mailto: jbentley@... <mailto:jbentley%40cotorelay.com> >
> P Please consider the environment before printing this email.
> This e-mail and any attachments are for the sole use of the intended
> recipients and may be privileged or confidential. Any distribution,
> printing or other use by anyone else is prohibited. If you are not an
> intended recipient, please contact the sender immediately, and
> permanently delete this e-mail and attachments.
from Test to Live?
Patrick Winter
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Giese
Joshua Giese
CTO
From: "Bill Turgeon" <bturgeon@... <mailto:bturgeon%40cotorelay.com> >
Regards,
Bill Turgeon
66 Whitecap Drive
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
Patrick,
We used solution manager when we moved from test to live. Though all we had at the time were some BPM’s, a few customizations and a some BAQ’s/Dashboards. Everything went over perfect.
We also did it once again when we updated from 700c to 701. This time we had some issues with BAQ’s getting broken thus breaking some dashboards too. Otherwise BPM’s and customizations continued to work.
Jordan
[Bully Dog Logo]<http://www.bullydog.com>
Jordan Klassen | Information Technology
TEL: 940-783-9914 ext: 1828
Confidentiality Notice: The information contained in this electronic message is privileged and confidential information intended only for the use of the individual entity or entities named as recipient or recipients. If the reader is not the intended recipient, you are hereby notified that any dissemination, distribution or copy of this communication is strictly prohibited. If you have received this communication in error, please notify the sender immediately by electronic mail and permanently delete this message from your computer system. Thank you.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Winter, Patrick
Sent: Thursday, April 04, 2013 11:08 AM
Subject: RE: [Vantage] Epicor 9.05.700 - Solution Manager
from Test to Live?
Patrick Winter
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Joshua Giese
Joshua Giese
CTO
From: "Bill Turgeon" <bturgeon@...<mailto:bturgeon%40cotorelay.com> <mailto:bturgeon%40cotorelay.com> >
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Regards,
Bill Turgeon
66 Whitecap Drive
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
E-mail: bturgeon@...<mailto:bturgeon%40cotorelay.com> <mailto:bturgeon%40cotorelay.com> <mailto: jbentley@...<mailto:jbentley%40cotorelay.com> <mailto:jbentley%40cotorelay.com> >
Hi Patrick,
I’ve used solutions manager, but with varying degrees of success for each area using 9.05.605. It was very successful for BAQ’s and Quick Searches. For customizations and Dashboards, it seemed to work, but we were told often by our VAR that we should export them manually and then import them. Therefore, for the production, we did that.
My recommendation is that if you have a large amount of items to move, restore a copy of your db to your Pilot db (if you have already gone live with new system or upgrade) and then test by using Solutions Manager to export those items.
Regards,
Sigfredo.
Sent: Thursday, April 04, 2013 1:08 PM
from Test to Live?
Patrick Winter
Joshua Giese
CTO
From: "Bill Turgeon" <bturgeon@... <mailto:bturgeon%40cotorelay.com> <mailto:bturgeon%40cotorelay.com> >
Regards,
Bill Turgeon
66 Whitecap Drive
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
E-mail: bturgeon@... <mailto:bturgeon%40cotorelay.com> <mailto:bturgeon%40cotorelay.com> <mailto: jbentley@... <mailto:jbentley%40cotorelay.com> <mailto:jbentley%40cotorelay.com> >
BPM’s also were moved successfully for us using Solutions Manager…
Sigfredo.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jordan Klassen
Sent: Thursday, April 04, 2013 1:10 PM
Patrick,
Jordan
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of Winter, Patrick
from Test to Live?
Patrick Winter
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On Behalf Of Joshua Giese
Joshua Giese
CTO
From: "Bill Turgeon" <bturgeon@... <mailto:bturgeon%40cotorelay.com> <mailto:bturgeon%40cotorelay.com> <mailto:bturgeon%40cotorelay.com> >
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Regards,
Bill Turgeon
66 Whitecap Drive
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
E-mail: bturgeon@... <mailto:bturgeon%40cotorelay.com> <mailto:bturgeon%40cotorelay.com> <mailto:bturgeon%40cotorelay.com> <mailto: jbentley@... <mailto:jbentley%40cotorelay.com> <mailto:jbentley%40cotorelay.com> <mailto:jbentley%40cotorelay.com> >
> from Test to Live?
> Patrick Winter
> Joshua Giese
> CTO
> Regards,
> Bill Turgeon
> 66 Whitecap Drive
> Ph: 401-583-7223
> Cell: 401-368-9938
> Fax: 401-942-0920
