Epicor 9.05.700C - BAQ Question
Did you try creating an external baq and pointing it back at your Epicor DB?
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Tuesday, June 10, 2014 9:36 AM
Subject: RE: [Vantage] Epicor 9.05.700C - BAQ Question
Sad, isn't it? J
Sent: Tuesday, June 10, 2014 10:33 AM
Wow!
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
Sent: Tuesday, June 10, 2014 7:31 AM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
All in use
Sent: Tuesday, June 10, 2014 10:28 AM
Is there some reason that you could not use one of the user defined tables that already exist in the database?
Sent: Tuesday, June 10, 2014 6:39 AM
Subject: [Vantage] Epicor 9.05.700C - BAQ Question
Is there any way t o use a non-epicor SQL table in a BAQ?
I had to create a new table in the Epicor905 instance and would like to access it with a BAQ?
Any assistance is greatly appreciated.
Regards,
Bill Turgeon
D irector, Information Technology
Coto Technology, Inc.
66 Whitecap Drive
North Kingstown, RI 02852
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
E-mail: Bill.Turgeon@...<mailto:Bill.Turgeon@...<mailto:Bill.Turgeon@...%3cmailto:Bill.Turgeon@...>> *(formerly bturgeon@...<mailto:bturgeon@...<mailto:bturgeon@...%3cmailto:bturgeon@...>>)
[Picture1]
P Please consider the environment before printing this email.
This e-mail and any attachments are for the sole use of the intended recipients and may be privileged or confidential. Any distribution, printing or other use by anyone else is prohibited. If you are n ot an intended recipient, please contact the sender immediately, and permanently delete this e-mail and attachments.
Is there any way to use a non-epicor SQL table in a BAQ?
Regards,
Bill Turgeon
Director, Information Technology
66 Whitecap Drive
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
E-mail: Bill.Turgeon@...<mailto:Bill.Turgeon@...> *(formerly bturgeon@...<mailto:bturgeon@...>)
[Picture1]
This e-mail and any attachments are for the sole use of the intended recipients and may be privileged or confidential. Any distribution, printing or other use by anyone else is prohibited. If you are not an intended recipient, please contact the sender immediately, and permanently delete this e-mail and attachments.
Bill,
The external BAQ allows you to connect to a database and access the items within it. I have used these to connect to SQL views to get data. The SQL view allows you to structure data to match your specific needs.
I don’t see the External BAQ on the menu
Sent: Tuesday, June 10, 2014 9:53 AM
Subject: [Vantage] Re: Epicor 9.05.700C - BAQ Question
Bill,
You can create an External BAQ which allows you to use tables and views in your database. Use the New | External Query to start. I've used these to connect to many views, where you can do more data manipulation in SQL.
Found it.  Thanks very much!!
Sent: Tuesday, June 10, 2014 9:57 AM
Is there a way to connect an external query to a non MSSQL DB like MySQL or PostgreSQL?
John
Regards,
Bill Turgeon
66 Whitecap Drive
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
[Picture1]
All in use
Regards,
Bill Turgeon
66 Whitecap Drive
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
[Picture1]
Wow!
All in use
Regards,
Bill Turgeon
66 Whitecap Drive
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
[Picture1]
Sad, isn’t it?  J
Wow!
All in use
Regards,
Bill Turgeon
66 Whitecap Drive
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
[Picture1]
