Epicor 9.05 700C, Information Worker Synch issue
Both server & clients were updated.
What I found out was the schema folder in isolated storage on the clients
did not update properly. Deleting the schema folder & re-synchronizing
outlook did the trick. Thanks for pointing in the right direction.
Liz
On Tue, Jan 15, 2013 at 5:38 PM, Ned <TechnoBabbly@...> wrote:
> Did you upgrade IW at the same time as well as update all the IW Clients?
> Not sure what version you updated from, but it sounds like a schema
> mismatch
> between the 2.
> -----Original Message-----
> Of
> th3doglady
> Sent: Tuesday, January 15, 2013 4:30 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Epicor 9.05 700C, Information Worker Synch issue
> We just upgraded to 700C. At that time, Information Worker stopped
> synchronizing CRM calls from outlook back to Epicor. Looks like they are
> synching from Epicor to Outlook fine, and other business objects seem to be
> synching fine. I am getting the following error in the synch log:
> Message>Error Synchronizing Business Entity 'CRM Calls'.
> Progress.Open4GL.Exceptions.SchemaValidationException: Schema mismatch for
> parameter number 2 in procedure BAQ/SQ/zIWCRMCall/Sink.p:Update. For column
> number 1, data type (CHARACTER) does not match (DATE). (13868)
> Not sure if it is the BAQ that is the issue. Has anyone experienced this?
> Thanks,
> Liz Ewaschuk
> SignalQuest, Inc.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
We just upgraded to 700C. At that time, Information Worker stopped synchronizing CRM calls from outlook back to Epicor. Looks like they are synching from Epicor to Outlook fine, and other business objects seem to be synching fine. I am getting the following error in the synch log:
Message>Error Synchronizing Business Entity 'CRM Calls'. Progress.Open4GL.Exceptions.SchemaValidationException: Schema mismatch for parameter number 2 in procedure BAQ/SQ/zIWCRMCall/Sink.p:Update. For column number 1, data type (CHARACTER) does not match (DATE). (13868)
Liz Ewaschuk
SignalQuest, Inc.
Not sure what version you updated from, but it sounds like a schema mismatch
between the 2.
th3doglady
Liz Ewaschuk
SignalQuest, Inc.
