Stephen,
Thanks for the tip. I have donwloaded and installed the new DMT version 1.04.2 which does show the addition of Global parts. This will get us over the first hurdle for further testing
Regards,
Scott
Regards,
Scott
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...> wrote:
> Hi Scott,
> DMT does support Global Parts, ensure you are using the latest version
> available from EpicWeb.
> However, you do need to have sonic and all the standard multi company
> elements working correctly for it to work.
> Typically you create the parts mark as global and then run the global
> part linking import to add them to the other companies.
> This establishes the links, but it is down to the multi company process
> to move the records to the IM tables and push through the details.
> Have you verified that your configuration is setup correctly and
> processing parts manually work correctly?
> Regards,
> Stephen
> Of scottbrydson
> Sent: 17 August 2010 16:49
> To: vantage@yahoogroups.com
> Subject: [Vantage] Epicor 9 Data migration tool (DMT) in a multi-company
> envir. (global parts)
> We have used DMT successfully, but have run into a limitation whereby
> DMT does not support the global parts table. As a result, jobs with
> parts checked as "global" do not run in MRP.
> We can get around the problem temporarily by unchecking global, but this
> disables a big chunk of the multi-company capability we will need
> shortly after our launch.
> Does anyone share this problem, or have word on a DMT upgrade? We
> recently filed a support call on this.
