Epicor 9 DMT - how to make the "Bill of Operations" template "re
Mike,
You have to go with two files to load this.
first file loads operations standard and second file loads scheduled resources.
We are needing to make a mass substitution of some operations of MOMs but have found that when using the DMT, while it will change the operation, it will not “reload/refresh” the “details” of the scheduling resources for the new OpCode.  When doing it manually in the system, Epicor 9  will “ask” if you want to refresh Yes or No.   How do I get the DMT to default to selecting “YES” on that question????
Sorry to bump the original question up but I’m REALLY hoping someone can answer this..
Best regards
Mike Abell
IT ManagerW
Flexial Corporation
a company of BOA Group
1483 Gould Drive, Cookeville, TN 38506, USA
Phone:    +1 931 432 8408
Fax:        +1 931 432 1889
Mail:        mabell@...
Website:  http://www.flexial.com
               http://
www.boagroup.com
I cannot answer your question on the DMT tool itself but have you tried the mass operation replace option under Engineering workbench to see if that would work for you?
I’m not sure if it will do what you are seeking….
Manasa
Sent: Friday, March 11, 2016 10:10 AM
Subject: [Vantage] Epicor 9 DMT - how to make the "Bill of Operations" template "refresh" the operations with the new updated scheduling resources from the new OpCode info after replacing them
Best regards
Mike Abell
IT ManagerW
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
Manasa, thanks for the answer.  We have several “rules” we had to go through to “figure out” what the new OP codes have to be so using that Mass replace deal isn’t an option since it’s simply a “one to one” swapout.  The DMT tool works except it just doesn’t update the scheduling resources which I know people don’t always “want” to do (which is why Epicor in the application “asks” the question).  I just need to know if there’s some “switch” or something within the DMT that would make it work….
Sent: Friday, March 11, 2016 9:34 AM
Subject: [Vantage] RE: Epicor 9 DMT - how to make the "Bill of Operations" template "refresh" the operations with the new updated scheduling resources from the new OpCode info after replacing them
Manasa
Best regards
Mike Abell
IT ManagerW
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Ah…I think understand better….you are looking to add a specific scheduled resource against the new op based on whatever criteria, right?
Manasa
Sent: Friday, March 11, 2016 11:13 AM
Subject: RE: [Vantage] RE: Epicor 9 DMT - how to make the "Bill of Operations" template "refresh" the operations with the new updated scheduling resources from the new OpCode info after replacing them
Manasa
Best regards
Mike Abell
IT ManagerW
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Yes, exactly.  I have a query that has some serious logic in it to “figure out” what NewOpCode I want to use based on Old Op Code, Resource Group, Op Dtl Seq, etc etc…I then output that to a spreadsheet that I load into the DMT.  It runs like I want it to but the only kicker is that “by default” it Does NOT update the scheduling resources with the ones from the New OP code, it keeps the old ones.
Sent: Friday, March 11, 2016 10:31 AM
Manasa
Manasa
Best regards
Mike Abell
IT ManagerW
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Are you using two templates in DMT?
I remember having to use one template for PartOpr and another separate pass to update the PartOprDtl records.
Bruce, no I’m using just the one “Bill of Operations” template under the Engineering section in the DMT. It looks like it works like I want it except for it not updating the scheduling resources (as it should in my opinion)…
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Sent: Friday, March 11, 2016 11:07 AM
Subject: [Vantage] Re: Epicor 9 DMT - how to make the "Bill of Operations" template "refresh" the operations with the new updated scheduling resources from the new OpCode info after replacing them
What fields are you sending from the ECOOpDtl table? I always sent AltMethod and think I remember that being important.  The person who taught me DMT told me to go thru the change in the application and then mimic that in DMT. So don’t look at it as the refresh, but how would you change the scheduling resource on its own.
We don’t go to the resource level, but I sent these fields in addition to the ECOOpr fields.
ECOOpDtl#Company
ECOOpDtl#PartNum
ECOOpDtl#RevisionNum
ECOOpDtl#OprSeq
ECOOpDtl#AltMethod
Sent: Friday, March 11, 2016 12:16 PM
Subject: RE: [Vantage] Re: Epicor 9 DMT - how to make the "Bill of Operations" template "refresh" the operations with the new updated scheduling resources from the new OpCode info after replacing them
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
Yes, this happened to me the first time I tried methods too.
I had to run add a second template just to update the resources in the PartOpDtl records.
The DMT manual kind of implied that it would work with one just one template.
No matter what I tried, it pulled in the default scheduling ressource per the OpCode.
That sounds about right to me as well….but it has been so long and I am sure we never had anything as complicated as what you are trying to achieve.
Manasa
Sent: Friday, March 11, 2016 12:07 PM
Mike,
Are you trying to load just the new production standard?
can you send me your csv headers for the review?
sprostran@...
On Friday, March 11, 2016 12:06 PM, "bruce.d.ordway@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1982000716yiv8916882096ygrp-text">
  <div>Are you using two templates in DMT?<br clear="none">I remember having to use one template for PartOpr and another separate pass to update the PartOprDtl records.</div>
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096 -- #ygrps-yiv-1982000716yiv8916882096ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mkp #ygrps-yiv-1982000716yiv8916882096hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mkp #ygrps-yiv-1982000716yiv8916882096ads {
margin-bottom:10px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mkp .ygrps-yiv-1982000716yiv8916882096ad {
padding:0 0;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mkp .ygrps-yiv-1982000716yiv8916882096ad p {
margin:0;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mkp .ygrps-yiv-1982000716yiv8916882096ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-sponsor #ygrps-yiv-1982000716yiv8916882096ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-sponsor #ygrps-yiv-1982000716yiv8916882096ygrp-lc #ygrps-yiv-1982000716yiv8916882096hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-sponsor #ygrps-yiv-1982000716yiv8916882096ygrp-lc .ygrps-yiv-1982000716yiv8916882096ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096activity span {
font-weight:700;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096activity span span {
color:#ff7900;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096activity span .ygrps-yiv-1982000716yiv8916882096underline {
text-decoration:underline;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 .ygrps-yiv-1982000716yiv8916882096attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 .ygrps-yiv-1982000716yiv8916882096attach div a {
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 .ygrps-yiv-1982000716yiv8916882096attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 .ygrps-yiv-1982000716yiv8916882096attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 .ygrps-yiv-1982000716yiv8916882096attach label a {
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 .ygrps-yiv-1982000716yiv8916882096bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 .ygrps-yiv-1982000716yiv8916882096bold a {
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 dd.ygrps-yiv-1982000716yiv8916882096last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 dd.ygrps-yiv-1982000716yiv8916882096last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 dd.ygrps-yiv-1982000716yiv8916882096last p span.ygrps-yiv-1982000716yiv8916882096yshortcuts {
margin-right:0;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 div.ygrps-yiv-1982000716yiv8916882096attach-table div div a {
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 div.ygrps-yiv-1982000716yiv8916882096attach-table {
width:400px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 div.ygrps-yiv-1982000716yiv8916882096file-title a, #ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 div.ygrps-yiv-1982000716yiv8916882096file-title a:active, #ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 div.ygrps-yiv-1982000716yiv8916882096file-title a:hover, #ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 div.ygrps-yiv-1982000716yiv8916882096file-title a:visited {
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 div.ygrps-yiv-1982000716yiv8916882096photo-title a, #ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 div.ygrps-yiv-1982000716yiv8916882096photo-title a:active, #ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 div.ygrps-yiv-1982000716yiv8916882096photo-title a:hover, #ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 div.ygrps-yiv-1982000716yiv8916882096photo-title a:visited {
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 div#ygrps-yiv-1982000716yiv8916882096ygrp-mlmsg #ygrps-yiv-1982000716yiv8916882096ygrp-msg p a span.ygrps-yiv-1982000716yiv8916882096yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 .ygrps-yiv-1982000716yiv8916882096green {
color:#628c2a;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 .ygrps-yiv-1982000716yiv8916882096MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 o {
font-size:0;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096photos div {
float:left;width:72px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096reco-category {
font-size:77%;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096reco-desc {
font-size:77%;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 .ygrps-yiv-1982000716yiv8916882096replbq {
margin:4px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mlmsg select, #ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 input, #ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mlmsg pre, #ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 code {
font:115% monospace;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-mlmsg #ygrps-yiv-1982000716yiv8916882096logo {
padding-bottom:10px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-msg p#ygrps-yiv-1982000716yiv8916882096attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-reco #ygrps-yiv-1982000716yiv8916882096reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-sponsor #ygrps-yiv-1982000716yiv8916882096ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-sponsor #ygrps-yiv-1982000716yiv8916882096ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-sponsor #ygrps-yiv-1982000716yiv8916882096ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1982000716 #ygrps-yiv-1982000716yiv8916882096 #ygrps-yiv-1982000716yiv8916882096ygrp-vital ul li:last-child {
border-right:none !important;}
You have to use the additional fields from the template.  Fields like ECOOpDtl#ResourceGrpID.  Plus some other ones as well, I think 4 other ones.  I took me a long time to figure that out.
Sent: Friday, March 11, 2016 10:37 AM
Manasa
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
Miguel, thanks, I’ll go down that road and see if it works…..
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Sent: Monday, March 14, 2016 12:15 PM
To: 'vantage@yahoogroups.com'
Manasa
Disclaimer
Mike,
Easy to forget about but Tracing may allow you to see what is going on during "refresh" ...run thru your process of changing one Operation out and just before getting into the sub step of refreshing, turn on Tracing and make a trace of the detailed methods called and data sent.  That will tell you where and what to trigger additionally to refresh en-mass.
If you have service connect, you could do this in a looping process or as part of the Op swap instead of using DMT.
-Henry
Mike,
For what it's worth. I'm on E10.0.700.4, but it's probably pretty close. Here something we did last year when we took out some alternate methods and set up new primary methods. I don't remember what all we did now, but here's an entry that might help.
Company ECOGroupID Plant PartNum RevisionNum OpCode OprSeq AltMethod SubContract LaborEntryMethod QtyPer ProdStandard StdFormat StdBasis RFQNeeded ECOOpDtl#OprSeq ECOOpDtl#OpDtlSeq ECOOpDtl#ResourceGrpID PrimarySetupOpDtl PrimaryProdOpDtl
BG JT CARLISLE 2-HR26CS A10 AssyC 10 FALSE Q 1 0.5 HP E FALSE 10 20 ASSY-GC 20 20
BG JT CARLISLE H27F A10 AssyC 10 FALSE Q 1 1 HP E FALSE 10 20 ASSY-GC 20 20
BG JT CARLISLE H27F A10 PaintC 20 FALSE Q 1 8 HP E FALSE 20 20 PAINT-GC 20 20
BG JT CARLISLE H30F A10 AssyC 10 FALSE Q 1 1 HP E FALSE 10 20 ASSY-GC 20 20
BG JT CARLISLE H30F A10 PaintC 20 FALSE Q 1 8 HP E FALSE 20 20 PAINT-GC 20 20
I think this will paste in a spreadsheet okay.
Luck,
Joe
On Mon, Mar 14, 2016 at 3:47 PM, Mike Abell mabell@... [vantage] <vantage@yahoogroups.com> wrote:
Ă‚
<div>
  <p>
Ă‚
Best regards
Mike Abell
IT Manager
Flexial Corporation
Phone:Ă‚ Ă‚ Ă‚ +1 931 432 8408
Fax:Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ +1 931 432 1889
Mail:Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ mabell@...
Website:Ă‚ http://www.flexial.com
Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ Ă‚ http://
www.boagroup.com
Ă‚
Ă‚
Ă‚
You have to use the additional fields from the template.Ă‚ Fields like ECOOpDtl#ResourceGrpID.Ă‚ Plus some other ones as well, I think 4 other ones.Ă‚ I took me a long time to figure that out.
Ă‚
Ă‚
Ă‚
Manasa
Ă‚
Ă‚
Ă‚
Ă‚
Ă‚
Disclaimer
</div>
<div style="color:#fff;min-height:0;"></div>
Joe, thanks so much.   I got a message back from Epicor after complaining that says if I put in an “undocumented” column in the spreadsheet that is called “RefreshResources” and set it to TRUE for the parts I wish to refresh the resources then it will do what I want.  If that works, that’s about as simple as it could be.  Of course, this was “undocumented” LOL….
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Sent: Monday, March 14, 2016 5:32 PM
Subject: Re: [Vantage] Re: Epicor 9 DMT - how to make the "Bill of Operations" template "refresh" the operations with the new updated scheduling resources from the new OpCode info after replacing them
Mike,
Luck,
Joe
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Manasa
Disclaimer
I'd like to see the "undocumented" features manual.
On Tue, Mar 15, 2016 at 8:42 AM, Mike Abell mabell@... [vantage] <vantage@yahoogroups.com> wrote:
Ă‚
<div>
  <p>
Ă‚
Best regards
Mike Abell
IT Manager
Flexial Corporation
www.boagroup.com
