Epicor 9 finite scheduling
Do you if Epicor fix it?
--- In vantage@yahoogroups.com, "Caster" <jproteau@...> wrote:
> After meeting with our Epicor Consultant we found that finite scheduling is not running correctly and will overload resources. We found that there is currently a call and a SCR in the works to get this fixed (whenever that might be). Is anyone else having this trouble and do you have any ideas around this? Also if you are experiencing this problem you can call into Epicor and have them add you to the call.
> Call #'s are:
> 33185 MPS (finite scheduling) and 7099 ESC (regarding global scheduling finite)
Call #'s are:
Which version are you experiencing this?
> Call #'s are:
> finite)
we are on 905602A SQL 32 Bit
> > Call #'s are:
> > finite)
Bad news! We have trouble with the Finite Scheduling on 405A too and Epicor suggest to us to upgrade to Epicor 9...
> Call #'s are:
