Mike,
Do you use Epicor Payroll? We don’t, but I would think Epicor should have some way similar to Job Adjustment that allows you to adjust time out after the fact. I actually missed your reference to knowing about Job Adjustment in your original question, sorry about that. I don’t know if Epicor support would have an answer for you or not. I do know that Job Adjustment allows you to put negative time in, so if there is something in Payroll you should be able to do the same thing.
Steve
Sent: Monday, February 22, 2016 12:00 PM
Subject: [Vantage] RE: Epicor 9-how to change indirect time entry after a capture/post?
Steve,
How can this be done if he wasn’t actually clocked into a job. He was just in an indirect clock in, not a production clock in. Is this still possible????
Best regards
Mike Abell
IT Manager
Flexial Corporation
a company of BOA Group
1483 Gould Drive, Cookeville, TN 38506, USA
Phone: +1 931 432 8408
Fax: +1 931 432 1889
Mail:
mabell@...
Website: http://www.flexial.com
http://www.boagroup.com
Sent: Friday, February 19, 2016 9:46 AM
You can use Job Cost Adjustment to make a change to Labor time.
Steve
Sent: Friday, February 19, 2016 9:17 AM
Subject: [Vantage] Epicor 9-how to change indirect time entry after a capture/post?
We did a capture and post yesterday prior to fixing an employee on the second shift that did not clock out. We clocked him out the next morning. If he had been in a job we would be able to fix that through Job adjustment but he was in indirect time (which previously
in our Vantage 8 system did not capture and post.). Is there a way to adjust his time?
Sent from Mike's IPhone6
