Thats correct, thanks for the clarification
--- On Fri, 9/18/09, BradF <Brad_feazell@...> wrote:
Subject: [Vantage] Re: Epicor 9 Installation.
Date: Friday, September 18, 2009, 3:24 PM
Â
Since Epicor 9 is a 32-bit app, you should use the 32-bit ODBC
administrator (even to connect to a 64-bit SQL Server). Of course this
only an issue if you are running Epicor 9 on 64-bit Windows Server in
which case you create your DSNs using C:\WINDOWS\system32 \odbcad32. exe.
Brad
--- In vantage@yahoogroups .com, Mark Wagner <mjfw2003@.. .> wrote:
> Are you running 32 bit or 64 bit SQL server? If is it 64bit then you
need to set up a 64 bit ODBC connection. If you are running 32 bit check
the security permissions on the database itself. I dont have access to
our server right now but I know we got it to work with the right
security
