If you're on version 9.05, try an updatable BAQ or dashboard in Epicor
instead of the web/etc methods required for earlier versions. Create a
BAQ on ShipHead with the PackNum & ShipComment (or whatever), and mark
the comment field as updatable. Test it in the Analyze tab - there's
your (ugly) manual method for go-live. Or it can be prettied up into a
dashboard.
Brian.
Of Mary Horsey
Sent: Tuesday, June 05, 2012 12:58 PM
Subject: RE: [Vantage] Re: Epicor 9 pack slip question
Would you tell me how to do this? Our IT person is out for surgery until
next week and we are going live on June 18 and we just wanted to iron
out a few issues before that date. Is it very complicated?
Mary Horsey
Greene Rubber Company
HR/Finance Manager
20 Cross Street
Woburn MA 01801
mhorsey@... <mailto:mhorsey%40greenerubber.com>
781-497-1851 (p)
781-937-7881 (f)
Behalf Of Vic Drecchio
Sent: Tuesday, June 05, 2012 12:36 PM
When this happens (with invoicing comments, too), I have created a web
dashboard that permits direct entry into the comments fields bypassing
Vantage's lock-down of that screen. That's the only solution I know.
<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf Of
Mary Horsey
Sent: Tuesday, June 05, 2012 12:14 PM
Sometimes we have to make a change to the pack slip because a customer
forget to let us know they needed information on the pack slip which is
also
our cert. I have not found a way to add new comments to a pack slip that
has
already been printed and shipped. Any help with this would be greatly
appreciated.
Mary Horsey
HR/Finance Manager
20 Cross Street
Woburn MA 01801
<mailto:mhorsey%40greenerubber.com> <mailto:mhorsey%40greenerubber.com>
781-497-1851 (p)
781-937-7881 (f)
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]
On
Behalf Of b_ordway
Sent: Thursday, May 24, 2012 4:42 PM
Subject: [Vantage] Re: MRP question
I usually set it for date of the next work day.
Below is text copied from the help screen:
Schedule Start Date
The date to be used for the start of job scheduling and MRP planning. If
a
forward scheduled job has a start date that falls before this date, then
this date will be used as the scheduled start date instead.
A scheduling method where you use a job's Start Date to calculate when
the
job should end. The Start Date is used as the beginning point; the job's
operation date intervals are then added together (or evaluated together
if
they are concurrent operations) to calculate the Due Date.
If scheduling in the past is not allowed (see Allow Historical Dates
below),
and a backward scheduled job is scheduled to start before this entered
Start
Date, the job will be scheduled forward using this date as the start
date.
A scheduling method where you use a job's Due Date to calculate when the
job
should begin. The scheduling engine uses the Required Date and subtracts
the
Receive days to get the Due Date.
This date is also the first date on which MRP plans. For example, if
this
date is two days in the future from now, and it is run now, then today
and
tomorrow are considered "past" for MRP purposes.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com>, Mary Horsey <mhorsey@...> wrote:
in Epicor 9.05. When she is running the MRP report there is a date
called
"scheduled start day". She has been leaving it set to the current date.
Is
that what everyone else does or does anyone ever set it do a past date?
Any
information would be greatly appreciated.
On
Behalf Of Winter, Patrick
<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On
Behalf
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2178 / Virus Database: 2433/5046 - Release Date:
06/05/12
dashboard.
Brian.
Of Mary Horsey
Mary Horsey
HR/Finance Manager
20 Cross Street
Woburn MA 01801
781-497-1851 (p)
781-937-7881 (f)
On Behalf Of
Mary Horsey
also
has
appreciated.
Mary Horsey
HR/Finance Manager
20 Cross Street
Woburn MA 01801
781-497-1851 (p)
781-937-7881 (f)
On
Behalf Of b_ordway
Schedule Start Date
a
the
if
below),
Start
date.
job
the
this
and
>MRP
> The Purchasing/Manufacturing Manager asked me to ask a question about
called
Is
Any
> Sincerely,
> Mary Horsey
> HR/Finance Manager
> 20 Cross Street
> Woburn MA 01801
> mhorsey@...
> 781-497-1851 (p)
> 781-937-7881 (f)
On
> Sent: Thursday, May 24, 2012 12:16 PM<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Subject: RE: [Vantage] Re: Database size is reaching limit<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Check your progress version, if it's new enough there is a switch to
> allow it grow over 2gb.
> Vantage 6.1 on Progress 9.1D Full allows this.
> Vantage 5.1 on Progress 9.1C Not sure.
> The database will log and entry when starting.
> "Large database file access has been enabled. (9426)"
> Plan b - you can break up the database in to multiple extents.
> Plan C - do a dump and load to gain extra space.
> Patrick
Behalf
> Of Manasa Reddy<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Sent: Thursday, May 24, 2012 10:50 AM
> Subject: RE: [Vantage] Re: Database size is reaching limit<mailto:manasa%40weldcoa.com> <mailto:manasa%40weldcoa.com>
> Version 5 doesn't have that option....
> M. Manasa Reddy
> manasa@... <mailto:manasa@...%3cmailto:manasa%40weldcoa.com>
> <mailto:manasa@... <mailto:manasa@...%3cmailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com> <mailto:manasa%40weldcoa.com> >
> 630.806.2000 x1515<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Ex scientia, vera
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Behalf Of cubcrafters_it<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Sent: Thursday, May 24, 2012 10:48 AM
> Subject: [Vantage] Re: Database size is reaching limitto
> How big of a limit is this?
> When we were on Vista 8, there was a 2GB limit, and we were just able
> flip a switch to allow it to grow past that size. Don't know if that's<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> relevant for you or not...
> <mailto:vantage%40yahoogroups.com>, "pagefigaro"[Non-text portions of this message have been removed]
> <pagefigaro@<mailto:pagefigaro@
> <mailto:pagefigaro@%3cmailto:pagefigaro@> >> wrote:
> > Our Progress database is reaching a size limit. In the past, we have
> had a database engineer work on this for us but he has since moved on
> and the company he worked for has gone out of business. We are in need
> to "compact" our database again. Can anyone provide some help or point
> us in a direction of help? Version of Vantage: 5.00.348, Version of
> Progress: 9.1A
06/05/12
