Since upgrading to 702, I have not seen any improvements in speed at all. Actually, we are a lot slower on certain processes. Granted, I have not yet had an opportunity to troubleshoot the performance, so hopefully when I do that I will see an improvement.
I recently added another SSD to my Database server, but have not seen much of an improvement from it either. Again, I need to play around with it a little to tweak it and that might get me some improvements, but have not had the chance.
Most of my time since the upgrade has been fixing small issues. For example, edit list not working, trackers not showing invoice numbers, Trial Balance reports not balancing and others.
--- In vantage@yahoogroups.com, "JEFFBOLL" <jeffboll@...> wrote:
> Just bought about a dozen SSD's for our PC's. We will see the improvement but the biggest improvement we have noticed is the printing and placing of images. The focus has to be keeping the image size as small as possible - no questions asked. We have out of memory issues because we put our logo on some reports. The logo itself is small 100KB (we had cases where it wasn't) but it was the way we placed the image on the document as well. If you don't do it right it will blow the size of the report out of the water.
> --- In vantage@yahoogroups.com, "Joseph" <jcrisino@> wrote:
> > We are also having performance issue since moving to 905.702 but ours seems to be remote plants. is there anybody that has terminal server running for remote sites and has seen an improvement in perforomance?
> > --- In vantage@yahoogroups.com, "mseal" <mseal@> wrote:
> > > Hi Patrick,
> > > Saw your commend on using SSD on client and servers – I have been using it on clients but holding back on server due to cost.
> > > Is there any way you can quantify the performance gains on the server side when moving from 15K RAID10 to SSD?
> > > Thanks
> > > Motty
> > > --- In vantage@yahoogroups.com, "Winter, Patrick" <pjw@> wrote:
> > > > Are you using any clients with SSD's? Having both server and client with SSD's is a wonderful thing.
> > > > Patrick Winter
> > > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of JEFFBOLL
> > > > Sent: Friday, May 31, 2013 13:21
> > > > To: vantage@yahoogroups.com
> > > > Subject: [Vantage] Re: Epicor 9 Performance Issues
> > > > Just thought I would tell my story. We are running 9.05.700b with 80 or so users plus an additional 80 MES/handheld devices. We have 4 locations. We are putting in a new server this weekend due to our performance, Epicor has recommended this as we have had them investigate to understand our issues. Our database is only around 8-9 gig but we have poor performance. Our spec for the new server is below and it is as big as we can get to try to conduct business as needed. Seems a bit crazy to me but after going to insights and talking to others i'm not the only one in this boat....
> > > > HP DL560P Gen8
> > > > E7-4650 8 core proc, 2.7GHz ( qty 4)
> > > > HP 16gb 2Rx4 PC3-12800R-11 (qty 8)
> > > > HP 200gb 6G SAS SLC 2.1in SC EP SSD (qty 4)
> > > > HP 785gb MLC G2 PCIe IO Accelerator
> > > > We are crossing our fingers that this really helps!
> > > > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Chris Thompson <chriselectrix@> wrote:
> > > > > Do you regularly restart your apps and db?
> > > > > ________________________________
> > > > > From: mbarryjr1 <mikebarry@>
> > > > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > > > Sent: Saturday, 11 May 2013, 3:35
> > > > > Â
> > > > > Hi Ted - did you find a solution? We're seeing the same issue lately.
> > > > > Mike
> > > > > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Ted Koch <tkoch77@> wrote:
> > > > > > We have recently started seeing sluggishness in Epicor the past couple months as well. We did a dump and load and reindex but it still sometimes takes 5-10 seconds if not longer to open a job in job entry or to save records. Interested too what people are doing/have done to get better performance. Is there a guide Epicor provides that would show how to tweak the database or anything else to get better performance?
> > > > > > From: supertico05 <mvissuet@>
> > > > > > Sent: Thursday, April 18, 2013 10:55 AM
> > > > > > Subject: [Vantage] Epicor 9 Performance Issues
> > > > > > Recently our Epicor performance went from OK to Horrible.Â
> > > > > > We are currently on 9.05.606, Progress Database.
> > > > > > MRP used to take about 5 to 6 hours to run, now it takes 15 hours.
> > > > > > Releasing jobs used to take 1 second now takes a minute.
> > > > > > Same for POs.
> > > > > > We didn't add any BPMs or change any settings.
> > > > > > Has anyone experienced similar issues and resolved them some how?
> > > > > > I've heard in the past that if a data table on a progress database reaches 2 million records that it slows down the database... can anyone confirm this?
> > > > > > our change log table is 15 million records. TranGLC is 1.99 million records and GLJrnlGLC is 1.76 million.
> > > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
> > > > > > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/. <http://groups.yahoo.com/group/vantage/files/>
> > > > > > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > > > > > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > > > > [Non-text portions of this message have been removed]
