Like the others already said, read the tuning guide.
To have Suggestions run faster look at changing the Number of Processes to a higher value. We found the number is not linear and you reach a point where it no longer improves performance. It can have negative effect on users during the day if you really increase the value, so test and tune until you reach a good balance point for your system. We tuned our system to run Regenerative PO Suggestions in 25 minutes from 2 hours previously.
Tim Lester
Tim Lester
--- In vantage@yahoogroups.com, John Driggers <waffqle@...> wrote:
> I'd second the recommendation to go through the tuning guide. There are a
> lot of things that can be a bit counter intuitive if you're not very
> familiar with the way OpenEdge works.
> Also, I'm not sure about MRP, but a lot of things like Generating
> Suggestions and such are not going to run faster because you have more
> active servers. They're basically a single thread that will grab one server
> and use it until it's done.
> *John Driggers*
> *Chief Data Wrangler*
> *I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
> *:: 904.404.9233
> :: waffqle@...
> :: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> On Mon, Oct 1, 2012 at 12:24 PM, b_ordway <cooner_55421@...> wrote:
> > Do you have the tuning guide? It's been a while since I have read it but I
> > think it will help answer your questions.
> > --- In vantage@yahoogroups.com, "Clive" <clive.1972@> wrote:
> > > Ah, I think that this is governed by the settings on the
> > database/Default Configuration ?.
> > > Can I increase the Maximum User and Server values by however I see fit,
> > as long as the server can take it ?.
> > > Thanks.
> > > --- In vantage@yahoogroups.com, "clive.1972" <clive.1972@> wrote:
> > > > I'm working towards upgrading to Epicor 9 and as the server is a beast
> > I'd like to start the Epicor905 and our additional Epicor905Print
> > AppServer's with as many Active Server's as possible, I'd like to run
> > things like Generate Suggestions and Process MRP with many multiple
> > processes/threads.
> > > > Testing things I've set both of the above to start with and initial
> > number 20 servers each, however, this then prevents me from starting the
> > ProcessServer and TaskAgent with the error in their logs being...
> > > > The server or the system has no more resources. Please contact
> > Progress Technical Support. (748)
> > > > ... is there an option I can alter so that more resources are
> > available, the server can handle it, or is this a hardcoded or licensing
> > issues with Progress ?.
> > > > Thanks.
