Epicor 9 - Qty-Adj in Mass
It has it’s own install..sort of, and yes, it is DMT.exe
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of amelie.pelletier@...
Sent: Wednesday, April 23, 2014 3:29 PM
Subject: RE: [Vantage] Re: Epicor 9 - Qty-Adj in Mass
Hi,
Is DMT not based in Epicor (epicor client file, dmt.exe?)
I am using Epicor 9.05.603 on a Progress database and have a need to adj-qty a lot of parts to zero on hand with various reason codes on a monthly basis.  I do have Service Connect and Progress 4GL programming knowledge but I am unsure how to handle this so all costs flow through to the GL as needed.
Can anyone please help point me in the right direction or give me a solution on how I can go about this.  The sooner I can get a resolution the better.
Thank you
Robert Nupp
We use the DMT tool to adj quantities on hand, simple spread sheet / csv.. reason codes are included in a column..
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of robert.nupp@...
Sent: Wednesday, April 23, 2014 2:08 PM
Subject: [Vantage] Epicor 9 - Qty-Adj in Mass
Thank you
Robert Nupp
We also use DMT for QOH adjustments.  We are currently on 9.05.607 but we have used it all along, since going live on 9.04.
This data is sample of DMT template / our upload:
Company PartNum WareHseCode BinNum AdjustQuantity ReasonCode Plant Reference LotNum TransDate
TEIK 104243050 PA MAIN PA-Z406 0.5 CC 10 PI Inventory  12/31/2013
TEIK 22020A110 PA MAIN PA-GOV04 -2 CC 10 PI Inventory 001834 12/31/2013
Nancy
We do not currently have DMT and are currently not interested in buying it for this purpose.  Has anyone developed a way to do this without DMT?
Why do you want to do a quantity adjustment in mass?
Sent: Wednesday, April 23, 2014 12:59 PM
Subject: [Vantage] Re: Epicor 9 - Qty-Adj in Mass
Have you tried an updatable dashboard. As for the costs to the GL, each Adj Reason Code can have a GL Associated to it.
If you have SC Knowledge, then you should be able to just create a CSV file and dump it to a directory so that the workflow picks it up.
Miguel A. Santillan
Compass Manufacturing Systems
510-661-6666  Office
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Cathy
Sent: Wednesday, April 23, 2014 1:07 PM
Hi,
