Epicor 9 replication SQL install
We are in the process of upgrading from vantage to epicor 9. It looks as if we will need SQL 2008 "full" based on our DB size. Since SQL express will not go beyond 10gb.
My question is, looking at the install guide it seems that you have to have Epicor 9 installed on the same server you intend to use as your SQL replication server.
Is that correct?
