Epicor 9 Source Control and Versioning Options
You should look at “Systems Management / Utilities / Solution Manager”.
This may answer some of what you’re looking for.
Patrick Winter
Sent: Friday, February 20, 2015 07:37
Subject: [Vantage] Epicor 9 Source Control and Versioning Options
Hello Everyone,
I am sure this has been discussed here, but I searched the conversations and did not find much information.
I was wondering what others are doing to source control and version their customization's, BPM's, BAQ's, and RDD's. I know that customization's, BPM's, and BAQ's can be exported out of Epicor as XML files which can then be controlled in whatever versioning software you want to use. I am unsure if you can do the same with RDD's.
I was also wondering if there was a more automated procedure. It seems a little tedious to have to check ut the XML, import the XML, make the change, export the XML, and check it back in.
Controlling all of these isn't too bad when you are the only developer, but when you have 2 or more the chance of overwrit ing someone else's code becomes an issue.
I would love your feedback.
- Scott
This e-mail and any attachments may contain confidential and privileged information. If you are not the intended and/or named recipient or recipients, please notify the sender immediately by return e-mail, delete this e-mail and destroy any copies. Any dissemination or use of this information by a person other than the intended recipient or recipients is unauthorized and may be illegal. Any views or opinions expressed in this email are those of the author and do not necessarily represent those of the Specialty Screw Corporation. Warning: Although precautions have been taken to make sure no viruses are present in this email, Specialty Screw Corporation cannot accept responsibility for any loss or damage that may arise from the use of this email or attachments.   ­­
Hello Everyone,
Controlling all of these isn't too bad when you are the only developer, but when you have 2 or more the chance of overwriting someone else's code becomes an issue.
- Scott
